GEA Test
- GEA Test
GEA Test
28-01-2020 4:13 PM
Hi PN
Could I have my line GEA Test please
Re: GEA Test
29-01-2020 12:54 PM - edited 29-01-2020 12:55 PM
Thanks for getting in touch @goldenfibre.
I've provided this for you below
Test Outcome | Pass |
Test Outcome Code | GTC_FTTC_SERVICE_0000 |
Description | GEA service test completed and no fault found . |
Main Fault Location | OK |
Sync Status | In Sync |
Downstream Speed | 79.9 Mbps |
Upstream Speed | 20.0 Mbps |
Appointment Required | N |
Fault Report Advised | N |
NTE Power Status | PowerOn |
Voice Line Test Result | Pass |
Bridge Tap | Not Detected |
Radio Frequency Ingress | Not Detected |
Repetitive Electrical Impulse Noise | Not Detected |
Cross Talk | Not Detected |
Estimated Line Length In Metres | 253.1 |
Upstream Rate Assessment | Very Good |
Downstream Rate Assessment | Very Good |
Interference Pattern | Not Detected |
Service Impact | No Impact Observed |
Home Wiring Problem | Not Detected |
Downstream Policing Discard Rate | 0.0 |
Customer Traffic Level | Upstream and Downstream Traffic Detected |
Technology | VDSL |
Current 15Min Bin Retrains | 0 |
Last 15Min Bin Retrains | 0 |
DP Type | External |
Profile Name | 0.128M-80M Downstream, Retransmission Low - 0.128M-20M Upstream, Error Protection Off |
Time Stamp | 2020-01-16T13:00:00 |
Parameters | MIN | MAX | AVG |
Down Stream Line Rate | 79.9 Mbps | 79.9 Mbps | 79.9 Mbps |
Up Stream Line Rate | 19.9 Mbps | 19.9 Mbps | 19.9 Mbps |
Up Time | 0.0 Sec | 900.0 Sec | 882.2 Sec |
Retrains | 0.0 | 3.0 | 0.0 |
Current and Last 15 Minute Bin Performance | ||
Parameters | Last Traffic Count(Upto 15 mins) | Current Traffic Count(Upto 15 mins) |
Start Time Stamp | 2020-01-29T12:36:13Z | 2020-01-29T12:51:13Z |
Ingress Code Violation | 0 | 0 |
Egress Code Violation | 0 | 0 |
Errored Seconds | 0 | 0 |
Severely Errored Seconds | 0 | 0 |
Unavailable Seconds | 0 | 0 |
Re: GEA Test
29-01-2020 12:55 PM - edited 29-01-2020 12:57 PM
Derrrrrrr it's showing now .😆😆😆
Re: GEA Test
29-01-2020 3:01 PM
Thanks for the GEA Test but what is this Traffic Detected by customer traffic level?
Re: GEA Test
29-01-2020 6:39 PM
@goldenfibre It means you are using your broadband connection. Traffic, that is data has been flowing downstream and upstream.😁
Re: GEA Test
30-01-2020 2:35 PM
What @RealAleMadrid said
