GEA Test
FIXEDTopic Options
- GEA Test
14-10-2018 10:44 PM
Message 1 of 4
(834 Views)
3 REPLIES 3
15-10-2018 3:17 PM
He's the GEA for your line. Please get back to us if we can assist further.
Test Outcome | Pass |
Test Outcome Code | GTC_FTTC_SERVICE_0000 |
Description | GEA service test completed and no fault found . |
Main Fault Location | OK |
Sync Status | In Sync |
Downstream Speed | 79.9 Mbps |
Upstream Speed | 20.0 Mbps |
Appointment Required | N |
Fault Report Advised | N |
NTE Power Status | PowerOn |
Voice Line Test Result | Pass |
Bridge Tap | Not Detected |
Repetitive Electrical Impulse Noise | Not Detected |
Estimated Line Length In Metres | 171.9 |
Upstream Rate Assessment | Very Good |
Downstream Rate Assessment | Very Good |
Interference Pattern | Not Detected |
Service Impact | No Impact Observed |
Home Wiring Problem | Not Detected |
Downstream Policing Discard Rate | 0.0 |
Customer Traffic Level | Upstream and Downstream Traffic Detected |
Technology | VDSL |
Profile Name | 0.128M-80M Downstream, Interleaving Low - 0.128M-20M Upstream, Error Protection Off |
Time Stamp | 2018-10-10T12:15:00 |
Parameters | MIN | MAX | AVG |
Down Stream Line Rate | 79.9 Mbps | 80.0 Mbps | 79.9 Mbps |
Up Stream Line Rate | 19.9 Mbps | 19.9 Mbps | 19.9 Mbps |
Up Time | 527.0 Sec | 900.0 Sec | 898.5 Sec |
Retrains | 0.0 | 1.0 | 0.0 |
Current and Last 15 Minute Bin Performance | ||
Parameters | Last Traffic Count(Upto 15 mins) | Current Traffic Count(Upto 15 mins) |
Start Time Stamp | 2018-10-15T13:47:11Z | 2018-10-15T14:02:11Z |
Ingress Code Violation | 0 | 0 |
Egress Code Violation | 0 | 0 |
Errored Seconds | 0 | 0 |
Severely Errored Seconds | 0 | 0 |
Unavailable Seconds | 0 | 0 |
Re: GEA Test
07-11-2018 12:11 PM
would it be possible to get another GEA Test for my line please?
Thanks,
Message 3 of 4
(730 Views)
Re: GEA Test
07-11-2018 8:58 PM
Hi @max3600
Estimated Line Length In Metres | 176.7 |
Technology | VDSL |
Profile Name | 0.128M-80M Downstream, Retransmission Low - 0.128M-20M Upstream, Error Protection Off |
Time Stamp | 2018-10-25T21:00:00 |
Down Stream Line Rate | 79.9 Mbps | 79.9 Mbps | 79.9 Mbps |
Up Time | 897.0 Sec | 900.0 Sec | 899.9 Sec |
Retrains | 0.0 | 0.0 | 0.0 |
Please get back to us if you have any further questions.
Message 4 of 4
(718 Views)
