GEA Test
DeclanTM
GEA Test
Could I have a GEA test performed on my line and have the results please, would like to know what profile I am on for VDSL, currently chasing a fault up but not sure if the DLM has banded me?
My username is [removed]
Thanks,
Declan
Moderator's note by Dick (Strat): Personal information removed from a public forum to a private staff area.
Fixes: 219
Re: GEA Test
Unfortunately from what I can see your connection isn't currently working so we can't see the profile at this moment in time.
 Matthew Wheeler
Shep41
Re: GEA Test
Would it be possible for a GEA test on my line. As I'm a nosey old git and Intrested in line lengthy etc
Fixes: 219
Re: GEA Test
@Shep41 I've attached a GEA test for your line below
Test Outcome Pass
Test Outcome Code GTC_FTTC_SERVICE_0003
Description No problem found, OAM test is not currently supported on this line.
Main Fault Location OK
Sync Status In Sync
Downstream Speed 78.4 Mbps
Upstream Speed 20.0 Mbps
Appointment Required N
Fault Report Advised N
NTE Power Status PowerOn
Voice Line Test Result Pass
Bridge Tap Not Detected
Cross Talk Not Detected
Estimated Line Length In Metres 253.1
Upstream Rate Assessment Very Good
Customer Traffic Level Upstream and Downstream Traffic Detected
Technology VDSL
Profile Name 0.128M-80M Downstream, Error Protection Off - 0.128M-20M Upstream, Error Protection Off
Time Stamp 2017-07-01T12:45:00
 Matthew Wheeler
Shep41
Re: GEA Test
Many thanks Matt
Champnet
Re: GEA Test
Would it be possible for a GEA test on my line. As I'm another nosey old git. Thanks...
Fixes: 219
Re: GEA Test
@Champnet Here's yours.
Test Outcome Pass
Sync Status In Sync
Downstream Speed 64.3 Mbps
Estimated Line Length In Metres 410.7
Downstream Rate Assessment Reasonable
Technology VDSL
Profile Name 0.128M-74M Downstream, Error Protection Off - 0.128M-20M Upstream, Error Protection Off
Time Stamp 2017-07-01T13:30:00
 Matthew Wheeler
Champnet
Re: GEA Test
Thank you very much, I'll have it framed.............
DeclanTM
Re: GEA Test
Openreach have now fixed the fault on my line, I don't think it has done anything to my sync but could I now have my profile to see current sync?
Thanks,
Declan
Fixes: 219
Re: GEA Test
@DeclanTM I think the engineer reset your line as I can't see a profile at the moment
 Matthew Wheeler
lzjoker
Re: GEA Test
Can i get a test too?
Fixes: 219
Re: GEA Test
@lzjoker Yours is attached below
Test Outcome Pass
Sync Status In Sync
Downstream Speed 68.2 Mbps
Upstream Speed 18.6 Mbps
Voice Line Test Result Voice fault suspected - contact Voice CP to progress copper issue
Technology VDSL
Current 15Min Bin Retrains 0
Last 15Min Bin Retrains 0
 Matthew Wheeler
Fixes: 6
Re: GEA Test
Can I have the test too please.
Fixes: 219
Re: GEA Test
@npr Why not
Test Outcome Pass
Sync Status In Sync
Downstream Speed 22.5 Mbps
Upstream Speed 0.5 Mbps
Estimated Line Length In Metres 1356.3
Upstream Rate Assessment Low
Downstream Rate Assessment Good
Technology VDSL
Profile Name 0.128M-40M Downstream, Error Protection Off - 0.128M-2M Upstream, Error Protection Off
Time Stamp 2017-07-04T16:15:00
 Matthew Wheeler
lzjoker
Re: GEA Test
What do i do regarding this:
