GEA Test
Nelstro
GEA Test
Would it be possible to have a GEA test for my line please.
Cheers
12 REPLIES 12
Fixes: 241
Re: GEA Test
Hi @Nelstro,
Here's the test for your connection.
It's changed since the initial testing when you reported the fault with your connection. I've also responded via the ticket on your account regarding this.
GEA Test Detail
Circuit ID NA Service ID [Removed]
Test Outcome Pass
Main Fault Location OK
Sync Status In Sync
Downstream Speed 35.0 Mbps
Upstream Speed 6.4 Mbps
Appointment Required N
Fault Report Advised N
NTE Power Status PowerOn
Voice Line Test Result Pass
Bridge Tap Not Detected
Cross Talk Not Detected
Estimated Line Length In Metres 783.2
Upstream Rate Assessment Low
Downstream Rate Assessment Reasonable
Technology VDSL
Profile Name 0.128M-35M Downstream, Retransmission High - 0.128M-20M Upstream, Error Protection Off
 Harry Beesley
 Plusnet Infrastructure Operations Professional
Nelstro
Re: GEA Test
Cheers, Harry. Much appreciated.
Fixes: 43
Re: GEA Test
@Nelstro you may want to ask for the banding to be removed:
Fixes: 241
Re: GEA Test
@Mustrum, I've already submitted that and confirmed it via the ticket :wink:
Apologies I didn't confirm that in my previous response here.
 Harry Beesley
Nelstro
Re: GEA Test
Has any progress been made on this? I have an update on my ticket saying they were waiting for test results but nothing since.
Fixes: 18
Re: GEA Test
Hi @Nelstro,
Thanks for getting in touch, I appreciate your query.
I can't see any update about this so have requested the information from the colleague who deals with such queries. He is back after the weekend so we should have more information then.
Thanks - LF
  Tahir M
Nelstro
Re: GEA Test
The line has speed has increased but isn't back to where it was, I have bought a 50cm cat6 modem cable to rule out any issues with the internal wiring and this has increased the line and signal attenuation values for the upstream connection dramatically but the downstream is still terrible, I am definitely thinking this is something from the BT side of things as the problems only started after there was a couple of engineers up the pole I am connected to a while back. Can another test be done on my line please, failing this I think it will need an engineer visit.
Cheers
Fixes: 55
Re: GEA Test
Hi @Nelstro
Your line is syncing at 42.2Mbps download.
These are within the estimates as per DSL Checker, and also shows that your line is no longer banded to 35M.
Are you noticing different speeds at your end?
Thanks,
MoR
 MoR
Nelstro
Re: GEA Test
Yes, the original speed was 53Mb before the problems started. Also, the BT speed checker puts my line speed at 36Mb for some bizarre reason.
Fixes: 55
Re: GEA Test
Thanks for getting back to me @Nelstro
Speeds can change over time, this can be due to a multitude of things not just line degradation. I am in the same situation at my house, I used to Sync at 73Mbps, now I am syncing at 62Mbps on a good day. Regrettably, if you are within your limits then our suppliers would not class this as a speed issue. If we raised it to them they would more than likely close it as "no fault present after testing". If an engineer did indeed get sent out for one reason of another, with the reason being noted as "sync speed" and tested the line to be syncing within limits, our suppliers may well impose their engineer charge for the visit - and that's the last thing we would want to happen.
Thanks,
MoR
 MoR
Nelstro
Re: GEA Test
I hear what you are saying, the line was stable at 53Mb since the initial bedding in period up until a few months ago when it dropped, I wouldn't say this was normal behaviour.
What would the engineer fee be if BT was to send an engineer for the problem?
Cheers
Fixes: 55
Re: GEA Test
@Nelstro
"If the engineer finds the problem is with your internal wiring, your equipment, the condition of your property or the Openreach network has been damaged within your property and its boundary, or if no fault is found, you will receive a charge of £65 to cover the cost of the engineer."
That is our standard engineer visit charge warning notice.
Thanks,
MoR
 MoR
