GEA Test
- Re: GEA Test
GEA Test
on
13-07-2017
11:24 PM
- last edited on
14-07-2017
11:41 AM
by
Strat
Could I have a GEA test performed on my line and have the results please, would like to know what profile I am on for VDSL, currently chasing a fault up but not sure if the DLM has banded me?
My username is [removed]
Thanks,
Declan
Moderator's note by Dick (Strat): Personal information removed from a public forum to a private staff area.
Re: GEA Test
14-07-2017 11:41 AM
Re: GEA Test
14-07-2017 12:23 PM
Re: GEA Test
14-07-2017 12:34 PM
@Shep41 I've attached a GEA test for your line below
Test Outcome | Pass |
Test Outcome Code | GTC_FTTC_SERVICE_0003 |
Description | No problem found, OAM test is not currently supported on this line. |
Main Fault Location | OK |
Sync Status | In Sync |
Downstream Speed | 78.4 Mbps |
Upstream Speed | 20.0 Mbps |
Appointment Required | N |
Fault Report Advised | N |
NTE Power Status | PowerOn |
Voice Line Test Result | Pass |
Bridge Tap | Not Detected |
Radio Frequency Ingress | Not Detected |
Repetitive Electrical Impulse Noise | Not Detected |
Cross Talk | Not Detected |
Estimated Line Length In Metres | 253.1 |
Upstream Rate Assessment | Very Good |
Downstream Rate Assessment | Very Good |
Interference Pattern | Not Detected |
Service Impact | No Impact Observed |
Home Wiring Problem | Not Detected |
Downstream Policing Discard Rate | 0.0 |
Customer Traffic Level | Upstream and Downstream Traffic Detected |
Technology | VDSL |
Profile Name | 0.128M-80M Downstream, Error Protection Off - 0.128M-20M Upstream, Error Protection Off |
Time Stamp | 2017-07-01T12:45:00 |
Re: GEA Test
14-07-2017 12:38 PM
Re: GEA Test
14-07-2017 12:41 PM
Would it be possible for a GEA test on my line. As I'm another nosey old git. Thanks...
Re: GEA Test
14-07-2017 1:34 PM
@Champnet Here's yours.
Downstream Speed | 64.3 Mbps |
Estimated Line Length In Metres | 410.7 |
Downstream Rate Assessment | Reasonable |
Technology | VDSL |
Profile Name | 0.128M-74M Downstream, Error Protection Off - 0.128M-20M Upstream, Error Protection Off |
Time Stamp | 2017-07-01T13:30:00 |
Re: GEA Test
14-07-2017 1:36 PM
Thank you very much, I'll have it framed.............
Re: GEA Test
14-07-2017 2:46 PM
Thanks,
Declan
Re: GEA Test
14-07-2017 3:50 PM
@DeclanTM I think the engineer reset your line as I can't see a profile at the moment
Re: GEA Test
15-07-2017 12:12 PM
Can i get a test too?
Re: GEA Test
17-07-2017 9:59 AM
@lzjoker Yours is attached below
Downstream Speed | 68.2 Mbps |
Upstream Speed | 18.6 Mbps |
Voice Line Test Result | Voice fault suspected - contact Voice CP to progress copper issue |
Technology | VDSL |
Current 15Min Bin Retrains | 0 |
Last 15Min Bin Retrains | 0 |
Re: GEA Test
17-07-2017 3:13 PM
Can I have the test too please.
Re: GEA Test
17-07-2017 4:12 PM
@npr Why not
Downstream Speed | 22.5 Mbps |
Upstream Speed | 0.5 Mbps |
Estimated Line Length In Metres | 1356.3 |
Upstream Rate Assessment | Low |
Downstream Rate Assessment | Good |
Technology | VDSL |
Profile Name | 0.128M-40M Downstream, Error Protection Off - 0.128M-2M Upstream, Error Protection Off |
Time Stamp | 2017-07-04T16:15:00 |
Re: GEA Test
17-07-2017 8:52 PM
What do i do regarding this:
