GEA Test request
goldenfibre
Fixes: 6
GEA Test request
Can PN staff please run the test on my line GEA Test and also RADIUS connection log please. Thanks.
P.S. I have decided to stay with PN afterall.
Fixes: 78
Re: GEA Test request
I've not included the RADIUS logs purely as you've had a solid connection for just over 7 days.
 Adam Walker
goldenfibre
Fixes: 6
@adamwalker
Profile Name: 0-128M-74M Downstream (is that meaning line is banded at 74M instead of 80M?)
GEA Test 13 12 2017.PNGOpen profile are banded at 74MGEA Test 25 06 2014.JPGOpen profile were unbanded at 80M
goldenfibre
Fixes: 6
@adamwalker please answer me if my line is banded or not?
Fixes: 62
You can see it yourself from the Profile which you have discussed at length over at Kitz Forum
As you have been advised many times you are stuck with it until the DLM updates
goldenfibre
Fixes: 6
Surely DLM should resolved and removed banded after 32 days stable connected? Some say it might never restore it back unless DLM reset perform by an engineer or a phone call to support team, Diagnostic Centre of Excellence by PN staff.
Fixes: 62
no it wouldn't as you will be aware after your multiple posts and replies by experts over at the other place
goldenfibre
Fixes: 6
No resync: 10th Nov 2017 (No DLM)
Downstream Upstream
Line attenuation (dB): 11.4 0.0
Signal attenuation (dB): Not available on VDSL2
Connection speed (kbps): 79999 19999
SNR margin (dB): 9.4 15.2
Power (dBm): 12.5 -0.9
Interleave depth: 16 1
INP: 48.00 0
G.INP: Enabled Not Enabled
1st resync: 11th Nov 2017 (DLM)
Downstream Upstream
Line attenuation (dB): 11.5 0.0
Connection speed (kbps): 79999 20000
SNR margin (dB): 8.3 13.9
Power (dBm): 12.4 -0.6
Interleave depth: 8 8
INP: 46.00 47.00
G.INP: Enabled Enabled
2nd resync: 12th Nov 2017 (DLM Banded)
Downstream Upstream
Connection speed (kbps): 73998 20000
SNR margin (dB): 10.1 14.0
Power (dBm): 12.5 -0.6
Interleave depth: 8 4
INP: 52.00 55.00
3rd resync: 22nd Nov 2017 (DLM Banded)
Downstream Upstream
Connection speed (kbps): 74000 20000
SNR margin (dB): 10.0 14.4
Interleave depth: 16 8
INP: 49.00 47.00
4th resync: 26th Nov 2017 (DLM Banded)
Downstream Upstream
Connection speed (kbps): 74000 19999
SNR margin (dB): 9.7 15.0
Power (dBm): 12.4 -1.0
INP: 49.00 0
DLM was 74Meg Banded since Nov 12th 2017 (ongoing for 32 days now as of today)
Fixes: 22
I think lots of us already know the history - what's your point? Tomorrow it will be 33 days, the day after that it will be 34 days, and so on until if and when it changes.
Cap your own line rate to 73Mb, then you won't be being capped by the DLM. You will have beaten the DLM at its own game.
