GEA Test Request
- GEA Test Request
GEA Test Request
on
03-03-2020
4:17 AM
- last edited on
03-03-2020
8:04 AM
by
Please can you run a GEA test on my line.
Plusnet username is [Removed]. Thank you.
Moderators Note: Personal information removed
Message 1 of 3
(249 Views)
2 REPLIES 2
Re: GEA Test Request
04-03-2020 11:39 AM
Can this be a actioned please.
Message 2 of 3
(161 Views)
08-03-2020 8:22 PM - edited 08-03-2020 8:22 PM
Hi @PLIW, sorry for the delay in responding.
Test Outcome | Pass |
Test Outcome Code | GTC_FTTC_SERVICE_0000 |
Description | GEA service test completed and no fault found . |
Main Fault Location | OK |
Sync Status | In Sync |
Downstream Speed | 49.2 Mbps |
Upstream Speed | 8.2 Mbps |
Appointment Required | N |
Fault Report Advised | N |
NTE Power Status | PowerOn |
Voice Line Test Result | Pass |
Bridge Tap | Not Detected |
Radio Frequency Ingress | Not Detected |
Repetitive Electrical Impulse Noise | Not Detected |
Cross Talk | Not Detected |
Estimated Line Length In Metres | 763.3 |
Upstream Rate Assessment | Good |
Downstream Rate Assessment | Very Good |
Interference Pattern | Not Detected |
Service Impact | No Impact Observed |
Home Wiring Problem | Not Detected |
Downstream Policing Discard Rate | 0.0 |
Customer Traffic Level | Upstream and Downstream traffic detected |
Technology | VDSL |
Current 15Min Bin Retrains | 0 |
Last 15Min Bin Retrains | 0 |
DP Type | External |
Profile Name | 0.128M-80M Downstream 4dB, Retransmission High - 0.128M-20M Upstream, Error Protection Off |
Time Stamp | 2020-02-24T20:30:00 |
Parameters | MIN | MAX | AVG |
Down Stream Line Rate | 50.8 Mbps | 55.1 Mbps | 52.7 Mbps |
Up Stream Line Rate | 8.0 Mbps | 8.2 Mbps | 8.1 Mbps |
Up Time | 0.0 Sec | 900.0 Sec | 889.9 Sec |
Retrains | 0.0 | 1.0 | 0.0 |
Current and Last 15 Minute Bin Performance | ||
Parameters | Last Traffic Count(Upto 15 mins) | Current Traffic Count(Upto 15 mins) |
Start Time Stamp | 2020-03-08T19:52:50Z | 2020-03-08T20:07:50Z |
Ingress Code Violation | 0 | 0 |
Egress Code Violation | 0 | 0 |
Errored Seconds | 0 | 0 |
Severely Errored Seconds | 0 | 0 |
Unavailable Seconds | 0 | 0 |
Message 3 of 3
(117 Views)
