GEA Test Request
- Re: GEA Test Request
GEA Test Request
25-08-2019 11:56 AM
Hi, Could I have a GEA test on my line please.
Thanks.
26-08-2019 11:23 AM
Hello @sweeep1963,
I have posted a GEA test below, please get back to us if you are experiencing any problems with your connection.
Test Outcome | Pass |
Test Outcome Code | GTC_FTTC_SERVICE_0000 |
Description | GEA service test completed and no fault found . |
Main Fault Location | OK |
Sync Status | In Sync |
Downstream Speed | 52.3 Mbps |
Upstream Speed | 10.7 Mbps |
Appointment Required | N |
Fault Report Advised | N |
NTE Power Status | PowerOn |
Voice Line Test Result | Pass |
Bridge Tap | Not Detected |
Radio Frequency Ingress | Not Detected |
Repetitive Electrical Impulse Noise | Not Detected |
Cross Talk | Not Detected |
Estimated Line Length In Metres | 711.6 |
Upstream Rate Assessment | Reasonable |
Downstream Rate Assessment | Very Good |
Interference Pattern | Regular Interference Observed Daily |
Service Impact | No Impact Observed |
Interference Duration Longest Occurrence | ;00:00to23:45 |
Interference Location | Customer Premise |
Interference Observed In Days | 14 |
Home Wiring Problem | Not Detected |
Downstream Policing Discard Rate | 0.0 |
Customer Traffic Level | Upstream and Downstream Traffic Detected |
Technology | VDSL |
Profile Name | 0.128M-80M Downstream 3dB, Retransmission High - 0.128M-20M Upstream, Error Protection Off |
Parameters | MIN | MAX | AVG |
Down Stream Line Rate | 54.6 Mbps | 55.3 Mbps | 55.2 Mbps |
Up Stream Line Rate | 10.6 Mbps | 10.7 Mbps | 10.7 Mbps |
Up Time | 795.0 Sec | 900.0 Sec | 899.7 Sec |
Retrains | 0.0 | 1.0 | 0.0 |
Current and Last 15 Minute Bin Performance | ||
Parameters | Last Traffic Count(Upto 15 mins) | Current Traffic Count(Upto 15 mins) |
Start Time Stamp | 2019-08-26T09:49:01Z | 2019-08-26T10:04:01Z |
Ingress Code Violation | 0 | 0 |
Egress Code Violation | 0 | 0 |
Errored Seconds | 0 | 0 |
Severely Errored Seconds | 0 | 0 |
Unavailable Seconds | 0 | 0 |
26-08-2019 11:33 AM
Hi, thank you for the response. Is there any way the line could return to retransmission low, as I believe this is why our speeds only seem to reach a maximum of about 47, despite the sync rate being mid 50s. We have had speeds of over 50 without any problems in the past.
Many thanks.
26-08-2019 4:10 PM
Hey @sweeep1963,
No worries, we're unable to influence the re transmission low as this is all up to the DLM settings on your profile. It might be worth looking at this website for more info.
Thanks.
