GEA TEST
iangilf
Re: GEA TEST
Thanks Adam
Fixes: 102
Re: GEA TEST
No problem, we'll do our best to follow things up with you as soon as we can after the visit.
 Adam Walker
iangilf
Re: GEA TEST
Nice 1
iangilf
Re: GEA TEST
hi can i have a full up to date gea test please
thanks
Fixes: 730
Re: GEA TEST
Thanks for getting back to us.
As requested I'm attaching a copy of our testing:
GEA Test Detail
Circuit ID NA Service ID [redacted]
Test Outcome Pass
Main Fault Location OK
Sync Status In Sync
Downstream Speed 67.2 Mbps
Upstream Speed 20.0 Mbps
Appointment Required N
Fault Report Advised N
NTE Power Status PowerOn
Voice Line Test Result Pass
Bridge Tap Not Detected
Cross Talk Not Detected
Estimated Line Length In Metres 358.2
Upstream Rate Assessment Very Good
Downstream Rate Assessment Reasonable
Customer Traffic Level Upstream and Downstream Traffic Detected
Technology VDSL
Profile Name 0.128M-80M Downstream, Error Protection Off - 0.128M-20M Upstream, Error Protection Off
Time Stamp 2019-07-19T20:30:00
Parameters MIN MAX AVG
Down Stream Line Rate 67.2 Mbps 70.9 Mbps 68.5 Mbps
Up Stream Line Rate 20.0 Mbps 20.0 Mbps 20.0 Mbps
Up Time 779.0 Sec 900.0 Sec 898.2 Sec
Retrains 0.0 1.0 0.0
Current and Last 15 Minute Bin Performance
Parameters Last Traffic Count(Upto 15 mins) Current Traffic Count(Upto 15 mins)
Start Time Stamp 2019-07-21T09:47:17.102+01:00 2019-07-21T10:02:17.102+01:00
Ingress Code Violation 0 1
Egress Code Violation 0 0
Errored Seconds 1 1
Severely Errored Seconds 0 0
Unavailable Seconds 0 0
iangilf
Re: GEA TEST
Cheers gandalf as I suspected speeds worse and still same thing happening
Fixes: 730
Re: GEA TEST
It's probably worth keeping an eye on your connection as your speeds are above the expectations of your line so it's unlikely another engineer will investigate further. If your sync speed drops below 62mbps or you get further disconnections feel free to raise another fault at faults.plus.net and we'll arrange another engineer visit with yourself.
iangilf
Re: GEA TEST
as i said gandalf mate the line still disconnects and isnt stable and its worse with the speed issue now
Fixes: 35
Re: GEA TEST
Hi @iangilf, I can certainly see that there's still some drops occurring. I've raised this back to our suppliers and they're requesting we send another engineer.
I've updated your fault ticket, if you let us know once you've replied we'll get it picked up for you.
 Lauren Barry
iangilf
Re: GEA TEST
hi ive replied to the ticket thanks very much
Fixes: 54
Re: GEA TEST
Thanks @iangilf.
I've updated the ticket but just to quickly let you know here that your appointment is now booked in between 08:00 & 13:00 on Wednesday 24th July.
Please let us all know how you get on.
 Owen P
iangilf
Re: GEA TEST
im giving up
ive completely had enough now
from a perfect line of 80/20 to this now
20.00 Mbps / 57.62 Mbps
28562 / 69306
10.1 dB / 6.3 dB
15.5 dB
0 dB / 15.5 dB
the engineers dont have a clue what there bloody doing
he did a lift and shift to a worse [-Censored-] port by the looks of things i know why my line is capable of the speeds are even worse now im going to go else where after all this i cant be dealing with this anymore
Fixes: 54
Re: GEA TEST
Thanks for getting back to us, @iangilf.
We're sincerely sorry to hear that this is the case.
As your speeds have gotten worse and have dropped below the minimum estimate, although not below your MGALS, I've rejected Openreach's report that the issue is resolved and we now await their instruction.
 Owen P
iangilf
Re: GEA TEST
Ok thank you
iangilf
Re: GEA TEST
When u have an update can u let me know please as this is very frustrating I've been working nights so stay up and wait for engineer on both occasions and it's gotten worse ...thanks very much
