GEA Line test request
FIXED- Subscribe to RSS Feed
- GEA Line test request
- « Previous
- 1
- 2
- Next »
Re: GEA Line test request
02-02-2018 3:11 PM - edited 02-02-2018 3:14 PM
@burnduck hi there your line was much similiar to mine. I had my line banded at 74Meg for almost 64 days after severe power loss and power cut intermitted by Western Power just a day before DLM kick in and decide to banded my line at 74Meg from 80Meg (which I have 80Meg for a very long time since 2014) However much thanks to @Gandalf who has raised my account passed onto BTw supplier as a DLM Remotely Resetted (caution counter) as part of the trial to reset my line without the need of engineer. And the line was successfully resetted by BTw and put my line back to 80Meg and removed banded line with all thanks to @Gandalf and BTw.
@burnduck if your line profile name is 0.128M-74M Downstream (then it appear your line are banded by DLM)
Here is my history stats of first DLM and resetted DLM by BTw:
1st Remote Defect Indicator/DLM resync: 26th Nov 2017 at 12:55pm (line banded enabled) Downstream Upstream Line attenuation (dB): 11.4 0.0 Signal attenuation (dB): Not available on VDSL2 Attenuation rate (kbps): 89238 30218 Connection speed (kbps): 74000 19999 SNR margin (dB): 9.9 15.1 Power (dBm): 12.5 -0.9 Interleave depth: 16 1 INP: 49.00 0 G.INP: Enabled Not Enabled 2nd Remote Defect Indicator/DLM resync: 29th Jan 2018 at 6:10pm (after 64 days stable & DLM resetted) Downstream Upstream Line attenuation (dB): 11.3 0.0 Signal attenuation (dB): Not available on VDSL2 Attenuation rate (kbps): 83026 27648 Connection speed (kbps): 69594 19999 SNR margin (dB): 6.2 15.2 Power (dBm): 12.5 -1.3 Interleave depth: 1363 1 INP: 3.00 0 G.INP: Not Enabled Not Enabled 3rd Remote Defect Indicator/DLM resync: 1st February 2018 at 1:45pm (after 3 days stable & restored) Downstream Upstream Line attenuation (dB): 11.3 0.0 Signal attenuation (dB): Not available on VDSL2 Attenuation rate (kbps): 82489 27617 Connection speed (kbps): 79999 19999 SNR margin (dB): 6.7 15.1 Power (dBm): 12.4 -1.3 Interleave depth: 8 1 INP: 48.00 0 G.INP: Enabled Not Enabled
- « Previous
- 1
- 2
- Next »
