GEA Line test request
burnduck
Hi Plusnet,
Following my recent Openreach fault repair can you please provide me with a GEA report?
It would be nice if you could check the caution counter and let me know the current threshold.
Thanks!
15 REPLIES 15
burnduck
Re: GEA Line test request
Anyone from Plusnet please? Smiley
Fixes: 1,600
Here you go... Though I don't think the information you're wanting is on our tests. Sad
Test Outcome Pass
Main Fault Location OK
Sync Status In Sync
Downstream Speed 74.0 Mbps
Upstream Speed 20.0 Mbps
Appointment Required N
Fault Report Advised N
NTE Power Status PowerOn
Voice Line Test Result Pass
Bridge Tap Not Detected
Estimated Line Length In Metres 138.3
Upstream Rate Assessment Very Good
Downstream Rate Assessment Reasonable
Customer Traffic Level Upstream and Downstream Traffic Detected
Technology VDSL
Current 15Min Bin Retrains 0
Last 15Min Bin Retrains 0
Profile Name 0.128M-74M Downstream, Error Protection Off - 0.128M-20M Upstream, Error Protection Off
Time Stamp 2018-01-05T15:00:00
Parameters MIN MAX AVG
Down Stream Line Rate 73.9 Mbps 73.9 Mbps 73.9 Mbps
Up Stream Line Rate 19.9 Mbps 19.9 Mbps 19.9 Mbps
Up Time 612.0 Sec 900.0 Sec 899.7 Sec
Retrains 0.0 1.0 0.0
Current and Last 15 Minute Bin Performance
Parameters Last Traffic Count(Upto 15 mins) Current Traffic Count(Upto 15 mins)
Start Time Stamp 2018-01-17T14:17:02Z 2018-01-17T14:32:02Z
Ingress Code Violation 0 0
Egress Code Violation 0 0
Errored Seconds 0 0
Severely Errored Seconds 0 0
Unavailable Seconds 0 0
burnduck
Thanks Gandalf, it's good to know what the line is currently doing.
Is it possible for you to check when my DLM profile is going to put back up again?
I've had a fault (copper joint issue) which caused disconnection every 5-10 minutes in the first week of activation, the fault was identified and fixed by an openreach engineer, but when I asked about DLM reset they weren't sure and didn't do anything there.
I'm pretty confident my line is capable of more than 74M, is there anything you can do to make get my line back to the open profile / 0-80M? Or maybe an idea of how much longer before my line speed is boosted? That would be helpful too.
Thanks!
Fixes: 1,600
It's not something we can check. As an ISP we have absolutely no control over fibre DLM I'm afraid.
DLM should reset the profile in due course if your line remains stable. I can't provide a timeframe sadly.
burnduck
Are you able to repeat this test for me please?
On the plusnet Current Line Speed page it's now reporting 77.4 Mb (71Mb before), but I am not seeing speed improvement. (I was expecting maybe 4-5Mbps of increase)
Thanks!
Fixes: 1,600
Sure thing:
Test Outcome Pass
Sync Status In Sync
Downstream Speed 80.0 Mbps
Estimated Line Length In Metres 137.0
Technology VDSL
Time Stamp 2018-01-10T12:45:00
Down Stream Line Rate 73.9 Mbps 79.9 Mbps 75.2 Mbps
Up Time 865.0 Sec 900.0 Sec 899.9 Sec
Start Time Stamp 2018-01-23T12:17:29Z 2018-01-23T12:32:29Z
Ingress Code Violation 0 1
Errored Seconds 0 0
It looks like your sync rate is now 80mbps, so I've updated the speed profile on your account to 78000kbps.
Due to the way the system works, that's the maximum it goes up to.
It's also possible that the DLM profile at 74mbps is limiting your throughput.
burnduck
Thanks Galdalf!
I had to recycle the PPPoE connection (i have separate openreach modem) and I'm now seeing just under 74Mbps, progress! Thanks for that!
Like you said it's more than like I'm now reaching the DLM ceiling considering it's spot on with the profile. At this point I'll happily wait for things to improve further.
Question though, the 78000kbps you mentioned, was it another limiting factor? Can you briefly tell me what that is or how it work, so that I'll know for the future?
Thanks!
Fixes: 1,600
I'm glad to hear things have improved.
The speed profile on your account/current line speed in the member centre should match the IP profile, but occasionally the system is a bit slow to update automatically. From time to time, it needs a nudge.
This profile doesn't affect a lot of users anymore, but due to the way that connections with static IPs are routed across our network, it does unfortunately limit throughput if set too low. I posted more info on this here a while ago.
Shep41
Seasoned Pro
Fixes: 6
If you compare the two gea test. Look closely and the line length is different by 1.3 metres. Has your house suffered from subsidence 🤣🤣🤣🤣..why should the line length differ?Huh
burnduck
I hope I don't have a subsidence problem as I've only just moved in! Grin
Your question got me googling and looks like they test it by "Time-domain reflectometer", I suppose there's a degree of accuracy and therefore it could vary a little.
Or maybe my house was subsiding. Lips_are_sealed
https://en.wikipedia.org/wiki/Time-domain_reflectometer
Moderator's note by Mike (Mav): Full quote of preceding post removed as per Forum rules.
RealAleMadrid
Aspiring Hero
Fixes: 59
Have you noticed that the GEA test says "estimated line length" so it's a bit of a guess and not an actual measurement.Crazy3
Shep41
Seasoned Pro
Fixes: 6
@RealAleMadrid..... I only aim to be 100% perfect. 98% of the time 🤣
Shep41
Seasoned Pro
Fixes: 6
@RealAleMadrid..... I only aim to be 100% perfect. 98% of the time 🤣. Most of my posts are during the night when normal folks should be sleeping.. 😀
Browni
Aspiring Hero
Fixes: 60
