GEA Line test request
Terranova667
Fixes: 5
Hi can someone from Plusnet staff run a GEA test please, about 2 months back i awoke to no dial tone which was reported it came back by the end of the day but i had loss some dowwnload speed it went from 45.6Mb down to 41.8Mb i tried a reboot a couple of days later but it sill held at 41.8Mb.
So I had left the modem until this morning hoping that some time would allow an increase but upon a reboot today it has still held at 41Mb with a minute increase to 41.9Mb lol, checking my Estimate i see that the top end has been increased from 48Mb to 55.5Mb so BTW / Openreach feel that the line could be capable of more but it seems to be holding firm at the 41Mb range almost as if it's banded there.
Does the GEA test show anything is the line banded in anyway or is it as I may suspect just further deterioration of my crappy Aluminium line and or more crosstalk.
3 REPLIES 3
MatthewWheeler
Fixes: 479
Re: GEA Line test request
GEA test below
Test Outcome Pass
Main Fault Location OK
Sync Status In Sync
Downstream Speed 43.3 Mbps
Upstream Speed 12.2 Mbps
Appointment Required N
Fault Report Advised N
NTE Power Status PowerOn
Voice Line Test Result Pass
Bridge Tap Not Detected
Cross Talk Not Detected
Estimated Line Length In Metres 697.2
Upstream Rate Assessment Reasonable
Downstream Rate Assessment Reasonable
Customer Traffic Level Upstream and Downstream Traffic Detected
Technology VDSL
Profile Name 0.128M-80M Downstream, Error Protection Off - 0.128M-20M Upstream, Error Protection Off
Time Stamp 2017-10-27T12:00:00
Parameters MIN MAX AVG
Down Stream Line Rate 43.2 Mbps 43.2 Mbps 43.2 Mbps
Up Stream Line Rate 10.8 Mbps 10.8 Mbps 10.8 Mbps
Up Time 0.0 Sec 900.0 Sec 899.0 Sec
Retrains 0.0 0.0 0.0
Current and Last 15 Minute Bin Performance
Parameters Last Traffic Count(Upto 15 mins) Current Traffic Count(Upto 15 mins)
Start Time Stamp 2017-11-09T11:32:49.835+00:00 2017-11-09T11:47:49.835+00:00
Ingress Code Violation 0 0
Egress Code Violation 0 0
Errored Seconds 1 0
Severely Errored Seconds 0 0
Unavailable Seconds 0
There's no DLM banding causing the sync speeds to be low and it's not detecting any causes.
 Matthew Wheeler
Terranova667
Fixes: 5
Thanks for the reply and test Matt it looks fine so it's as i thought that my line is degrading further and or more crosstalk.. ah well.
MatthewWheeler
Fixes: 479
Unfortunately that may be the case.
It may increase but we can't guarantee it
 Matthew Wheeler
