GEA Line test request
FIXED- Subscribe to RSS Feed
- Re: GEA Line test request
09-11-2017 9:37 AM
Hi can someone from Plusnet staff run a GEA test please, about 2 months back i awoke to no dial tone which was reported it came back by the end of the day but i had loss some dowwnload speed it went from 45.6Mb down to 41.8Mb i tried a reboot a couple of days later but it sill held at 41.8Mb.
So I had left the modem until this morning hoping that some time would allow an increase but upon a reboot today it has still held at 41Mb with a minute increase to 41.9Mb lol, checking my Estimate i see that the top end has been increased from 48Mb to 55.5Mb so BTW / Openreach feel that the line could be capable of more but it seems to be holding firm at the 41Mb range almost as if it's banded there.
Does the GEA test show anything is the line banded in anyway or is it as I may suspect just further deterioration of my crappy Aluminium line and or more crosstalk.
Fixed! Go to the fix.
09-11-2017 11:54 AM
GEA test below
Test Outcome | Pass |
Test Outcome Code | GTC_FTTC_SERVICE_0000 |
Description | GEA service test completed and no fault found . |
Main Fault Location | OK |
Sync Status | In Sync |
Downstream Speed | 43.3 Mbps |
Upstream Speed | 12.2 Mbps |
Appointment Required | N |
Fault Report Advised | N |
NTE Power Status | PowerOn |
Voice Line Test Result | Pass |
Bridge Tap | Not Detected |
Radio Frequency Ingress | Not Detected |
Repetitive Electrical Impulse Noise | Not Detected |
Cross Talk | Not Detected |
Estimated Line Length In Metres | 697.2 |
Upstream Rate Assessment | Reasonable |
Downstream Rate Assessment | Reasonable |
Interference Pattern | Not Detected |
Service Impact | No Impact Observed |
Home Wiring Problem | Not Detected |
Downstream Policing Discard Rate | 0.0 |
Customer Traffic Level | Upstream and Downstream Traffic Detected |
Technology | VDSL |
Profile Name | 0.128M-80M Downstream, Error Protection Off - 0.128M-20M Upstream, Error Protection Off |
Time Stamp | 2017-10-27T12:00:00 |
Parameters | MIN | MAX | AVG |
Down Stream Line Rate | 43.2 Mbps | 43.2 Mbps | 43.2 Mbps |
Up Stream Line Rate | 10.8 Mbps | 10.8 Mbps | 10.8 Mbps |
Up Time | 0.0 Sec | 900.0 Sec | 899.0 Sec |
Retrains | 0.0 | 0.0 | 0.0 |
Current and Last 15 Minute Bin Performance | ||
Parameters | Last Traffic Count(Upto 15 mins) | Current Traffic Count(Upto 15 mins) |
Start Time Stamp | 2017-11-09T11:32:49.835+00:00 | 2017-11-09T11:47:49.835+00:00 |
Ingress Code Violation | 0 | 0 |
Egress Code Violation | 0 | 0 |
Errored Seconds | 1 | 0 |
Severely Errored Seconds | 0 | 0 |
Unavailable Seconds | 0 | 0 |
There's no DLM banding causing the sync speeds to be low and it's not detecting any causes.
09-11-2017 12:14 PM
Thanks for the reply and test Matt it looks fine so it's as i thought that my line is degrading further and or more crosstalk.. ah well.
09-11-2017 12:28 PM
