GEA Line test request please
Suspect getting crosstalk at my local PCP seen our maximum data rate drop alot.
3 REPLIES 3
Fixes: 57
Re: GEA Line test request please
Hi @johng88
Welcome to the Forums.
I've tested your circuit and can see that your router is syncing at 40Mbps (the highest achievable for your product). No faults have been identified, nor Service Impact observed. The connection seems spot on from our side to be totally honest.
Can I ask where you have noticed this?
Thanks,
MoR
 MoR
Thank you for the reply back MoR. I've been noticing the maximum data rate been jumping about a bit it's not affecting my service yet which is good.
7. Maximum data rate: up 18771 / down 66457
8. Noise margin: 10.9 / 14.2
9. Line attenuation: 17.3 / 15.3
10. Signal attenuation: 17.1 / 15.3
Fixes: 75
Hi @johng88
Thanks for providing that info - as my colleague has suggested previously, all of the above including your new data looks absolutely fine.
Please let us know if you see anything service affecting.
Best wishes
Dave
