GEA Line Test Request
geforce
Hi Plusnet Support,
Can you provide me with the results of a GEA line test, please?
11 REPLIES 11
adamwalker
Fixes: 221
Re: GEA Line Test Request
 Adam Walker
oldjack
May i please request a GEA please. Is this a test to show the condition of my line and the speeds achievable ignoring PN settings or indeed BTW settings?
Chris
Legend
Fixes: 169
The GEA shows the raw sync data available to us. I'll grab that for you now.
Chris
Legend
Fixes: 169
Test Outcome Pass
Test Outcome Code GTC_FTTC_SERVICE_0001
Description GEA service test completed and no fault found but unable to check for customer equipment connected to modem.
Main Fault Location OK
Sync Status In Sync
Downstream Speed 38.2 Mbps
Upstream Speed 10.2 Mbps
Appointment Required N
Fault Report Advised N
NTE Power Status PowerOn
Voice Line Test Result Pass
Bridge Tap Not Detected
Estimated Line Length In Metres 725.9
Upstream Rate Assessment Reasonable
Downstream Rate Assessment Reasonable
Customer Traffic Level Upstream and Downstream Traffic Detected
Profile Name 0.128M-55M Downstream 6dB, Retransmission Low - 0.128M-20M Upstream, Error Protection Off
oldjack
Thank you Chris.....now what does it mean? I truly believed that my line was capable of a higher download speed than 38/39 .I realise PN has reduced my upstream speed. My router/modem is showing 151 error pkts upstream with 34 dB att. downstream no errors and 6 db att. is this normal?
oldjack
The GEA looks good and I'm told that I have G.INP which is also a plus. My DSLCHECK shows  57.1 to 43.5 clean and 44 to 25 Impacted.I seem to be on the Impacted range ,why?
Chris
Legend
Fixes: 169
There's no way to put you on a specific range, the sync speed you receive is down to the capabilities of your line. If you're below the estimates it's worth reporting a fault for us to investigate.
MattyC
Fixes: 46
It could mean one of a few things, there's some good info here:
http://www.thinkbroadband.com/news/6173-bt-wholesale-checker-adds-more-information-for-fibre-connect...
The article tends to suggest that it could be your internal wiring.
It could also possibly be crosstalk - noise being caused by other user's connections. This can cause an effect over your sync rates over time.
oldjack
When fibre first came the master socket was changed and the internal wiring sorted by OR. At the outset the speeds were quite high but with increased traffic then I expected a drop. Plusnet advised me that as I was an average web user that the 40/20 would be my best ,most cost effective, choice. I feel that I'm now "stuck" in this banding and come what may the 55/10 will not give me download improvement but will impinge on,as it already does, on my upload. I really feel conned by Plusnet.
oldjack
Oh and the estimated "line length" on the GEA seems to be well over the top by anything from 30% to 50% dependant on which route I take following cable ducts.
geforce
Could I have another GEA test result please?
