GEA Check requested please
- GEA Check requested please
06-06-2019 9:17 AM
As Topic.
Re: GEA Check requested please
06-06-2019 10:53 AM - edited 06-06-2019 10:53 AM
Here you go:
GEA Test Detail | |||
Circuit ID | NA | Service ID | [redacted] |
Test Outcome | Pass | ||||
Test Outcome Code | GTC_FTTC_SERVICE_0000 | ||||
Description | GEA service test completed and no fault found . | ||||
Main Fault Location | OK | ||||
Sync Status | In Sync | ||||
Downstream Speed | 68.1 Mbps | ||||
Upstream Speed | 20.0 Mbps | ||||
Appointment Required | N | ||||
Fault Report Advised | N | ||||
NTE Power Status | PowerOn | ||||
Voice Line Test Result | Pass | ||||
Bridge Tap | Not Detected | ||||
Radio Frequency Ingress | Not Detected | ||||
Repetitive Electrical Impulse Noise | Not Detected | ||||
Cross Talk | Not Detected | ||||
Estimated Line Length In Metres | 339.1 | ||||
Upstream Rate Assessment | Very Good | ||||
Downstream Rate Assessment | Reasonable | ||||
Interference Pattern | Regular Interference Observed Daily | ||||
Service Impact | No Impact Observed | ||||
Interference Duration Longest Occurrence | ; 00:00 to 23:45 | ||||
Interference Location | Customer Premise | ||||
Home Wiring Problem | Not Detected | ||||
Downstream Policing Discard Rate | 0.0 | ||||
Customer Traffic Level | Upstream and Downstream Traffic Detected | ||||
Technology | VDSL | ||||
Profile Name | 0.128M-80M Downstream, Error Protection Off - 0.128M-20M Upstream, Error Protection Off | ||||
Time Stamp | 2019-05-24T11:00:00 |
Parameters | MIN | MAX | AVG |
Down Stream Line Rate | 67.3 Mbps | 79.9 Mbps | 72.3 Mbps |
Up Stream Line Rate | 20.0 Mbps | 20.0 Mbps | 20.0 Mbps |
Up Time | 0.0 Sec | 900.0 Sec | 896.9 Sec |
Retrains | 0.0 | 1.0 | 0.0 |
Current and Last 15 Minute Bin Performance | ||
Parameters | Last Traffic Count(Upto 15 mins) | Current Traffic Count(Upto 15 mins) |
Start Time Stamp | 2019-06-06T10:33:34.931+01:00 | 2019-06-06T10:48:34.931+01:00 |
Ingress Code Violation | 0 | 0 |
Egress Code Violation | 0 | 0 |
Errored Seconds | 0 | 0 |
Severely Errored Seconds | 0 | 0 |
Unavailable Seconds | 0 | 0 |
Nothing wrong that I can see, are you having any issues?
06-06-2019 11:24 AM
Nope, went away for a week on holiday, came back noticed i had some sort of powercut why i was away and my ip profile had gone back up to the old (77mb) been 65mb for the last year or so. Had to have one of the new smart meters installed so my power had to be switched of for 20 mins or so and i'm back on the 65mb (was nice why it lasted)
06-06-2019 11:33 AM
