G.INP
- G.INP
Re: G.INP
02-08-2015 3:38 AM
Just to summarize.
First G.INP was downstream only
Then it was downstream and upstream
Then it was downstream only
Now is it downstream only.
All above is despite having a Draytek 2860n with full support for G.INP down and up, and having perfect stable connection when working.
Re: G.INP
02-08-2015 11:56 AM
My cabinet was first enabled at the beginning of June so it didn't ever have G.INP MK1.
A week or so ago I had G.INP applied on the downstream and upstream. A few days ago it was entirely removed. A couple of days ago it was reapplied, but to the downstream only.
I'm now having errors on the upstream again (granted they are small) whereas with G.INP there were none. There's something about me that prefers less errors and more G.INP which doesn't really make sense as the erroring is just being converted to something else but either way it is annoying.
I still don't understand why G.INP was removed in the first place
Re: G.INP
17-08-2015 6:31 PM
Quote from: JasonMassey G.INP has just been removed on the UPSTREAM.
Just to summarize.
Just to add, yesterday G.INP on upstream was re-enabled.
Re: G.INP
17-08-2015 7:14 PM
Re: G.INP
17-08-2015 7:19 PM
Quote from: JasonMassey Just to add, yesterday G.INP on upstream was re-enabled.
That's interesting.
It has been recently noticed that some Huawei DSLAMS are having their chipset versions updated.
Mine was updated when the connection resynced at 00:49, 11th August from:-
ChipSet Vendor Id: BDCM:0xa44f
ChipSet VersionNumber: 0xa44f
To:-
ChipSet Vendor Id: BDCM:0xa459
ChipSet VersionNumber: 0xa459
Are you able to confirm whether or not your DSLAM's chipset has been recently updated?
Re: G.INP
17-08-2015 7:28 PM
My Vigor stats report this
CO ITU Version 0 - b5004244
CO ITU Version 1 - 434da459
DSLAM CHIPSET VENDOR BDCM
Re: G.INP
17-08-2015 7:38 PM
I'm not familiar with the output from a Vigor, so I wonder if the part I have highlighted in red above means the same thing.
Do you know if that has changed quite recently?
Re: G.INP
17-08-2015 7:40 PM
I've not been monitoring this data, so no idea if it's changed. Do agree however those numbers appear to be the same.
Re: G.INP
17-08-2015 7:55 PM
My interest is that I had G.INP removed from upstream some time ago (as happened to most of us).
My 1100m or so connection generally appeared to suit G.INP on both DS & US & I keep hoping it will be restored for US at some stage.
The recent chipset changes could however be related to preparation for Vectoring being enabled?
That could just be my vain hope though as my connection has been hit quite gradually, but severely by crosstalk over the last couple of years or so.
As per usual, BT's secrecy gives us no indication as to what these recent updates are intended to do for us
Re: G.INP
17-08-2015 9:40 PM
I noticed that I've lost a bit of speed somewhere, I just thought it was just down to the lightening we had last week.
Normal downstream 43999
[tt]
xdslcmd info --pbParams
xdslcmd: ADSL driver and PHY status
Status: Showtime
Retrain Reason: 0
Last initialization procedure status: 0
Max: Upstream rate = 6980 Kbps, Downstream rate = 46572 Kbps
Bearer: 0, Upstream rate = 6904 Kbps, Downstream rate = 39999 Kbps
Bearer: 1, Upstream rate = 0 Kbps, Downstream rate = 0 Kbps
Discovery Phase (Initial) Band Plan
US: (7,32) (871,1205) (1972,2782)
DS: (33,859) (1216,1961) (2793,3970)
Medley Phase (Final) Band Plan
VDSL Port Details Upstream Downstream
Attainable Net Data Rate: 6980 kbps 46572 kbps
Actual Aggregate Tx Power: 1.8 dBm 11.2 dBm
VDSL Band Status U0 U1 U2 U3 U4 D1 D2 D3
Line Attenuation(dB): 7.3 44.5 N/A N/A N/A 19.4 55.2 84.0
Signal Attenuation(dB): 7.3 44.0 N/A N/A N/A 21.6 54.9 N/A
SNR Margin(dB): 6.0 6.1 N/A N/A N/A 9.3 9.3 N/A
TX Power(dBm): -9.1 1.4 N/A N/A N/A 8.7 7.8 N/A
Downstream Upstream
General
rtx_tx 2254347 124
rtx_c 1608 116
rtx_uc 0 0
LEFTRS 0 2
minEFTR 40005 6901
errFreeBits 74968258 12904184
Bearer 0
RxQueue 136 12
TxQueue 34 6
G.INP Framing 18 18
G.INP Lookback 31 6
RRC Bits 24 24
Interleave depth 4 4
INP 52.00 42.00
INPRein 1.00 0.00
Delay 0 0
Bearer 1
Interleave depth 1 1
INP 2.50 4.00
INPRein 2.50 4.00
Delay 0 0
Stats recorded 17 Aug 2015 21:33:22
DSLAM/MSAN type: BDCM:0xa459 / v0xa459
Modem/router firmware: AnnexA version - A2pv6C038m.d24j
DSL mode: VDSL2 Profile 17a
Status: Showtime
Uptime: 1 day 10 hours 8 min 53 sec
Resyncs: 0 (since 16 Aug 2015 22:07:20)
Downstream Upstream
Line attenuation (dB): 24.6 0.0
Signal attenuation (dB): Not monitored
Connection speed (kbps): 39999 6904
SNR margin (dB): 9.3 6.0
Power (dBm): 11.2 1.8
Interleave depth: 4 4
INP: 52.00 42.00
G.INP: Enabled
RSCorr/RS (%): 0.0002 0.6049
RSUnCorr/RS (%): 0.0000 0.0000
ES/hour: 0 0
Status: Showtime
Retrain Reason: 0
Max: Upstream rate = 6984 Kbps, Downstream rate = 46572 Kbps
Attainable Net Data Rate: 6984 kbps 46572 kbps
SNR Margin(dB): 6.1 6.0 N/A N/A N/A 9.3 9.3 N/A
[/tt]
Re: G.INP
17-08-2015 10:32 PM
Quote from: 11110_110 [tt]Max: Upstream rate = 6980 Kbps, Downstream rate = 46572 Kbps
Bearer: 0, Upstream rate = 6904 Kbps, Downstream rate = 39999 Kbps[/tt]
That looks suspiciously like you've been put on a 40Mb service...
Re: G.INP
17-08-2015 10:42 PM
[tt]
Stats recorded 24 Mar 2015 20:18:35
DSLAM/MSAN type: BDCM:0xa41b / v0xa41b
Status: Showtime
Uptime: 4 hours 7 min 41 sec
Resyncs: 0 (since 24 Mar 2015 17:18:33)
Downstream Upstream
Line attenuation (dB): 24.3 0.0
Connection speed (kbps): 43999 6847
SNR margin (dB): 7.2 6.1
Power (dBm): 11.2 1.0
Interleave depth: 16 4
INP: 47.00 43.00
G.INP: Enabled
RSCorr/RS (%): 0.0021 1.1010
ES/hour: 0 0[/tt]
Re: G.INP
18-08-2015 2:58 PM
[tt]
Stats recorded 18 Aug 2015 14:52:52
Status: Showtime
Uptime: 9 hours 20 min 37 sec
Resyncs: 1 (since 16 Aug 2015 22:07:20)
Downstream Upstream
Connection speed (kbps): 43998 6813
SNR margin (dB): 7.1 6.1
INP: 52.00 43.00
G.INP: Enabled
RSCorr/RS (%): 0.0015 0.0074
ES/hour: 0 0[/tt]
Re: G.INP
19-08-2015 4:46 PM
DSLAM/MSAN type: BDCM:0xa48c / v0xa48c
Modem/router firmware: AnnexA version - A2pv6F039g1.d24m
Re: G.INP
25-08-2015 12:42 PM
Hasn't made much difference for me as I had the full 80/20 sync anyway and very few errors, only slight change is my SNR appears to move a little more now fluctuating between 9-10db.
