G.INP
- G.INP
Re: G.INP
01-07-2015 11:05 PM
I looked at the rollout of FTTC in both Birmingham and Crawley and noticed that up until a certain time (maybe late 2012 - early 2013) BT's own rollout was using Huawei manufactured cabs but then the started installing the ECI cabs which are apparently (openreach engineer) a lot cheaper than the Huawei's were...
and now more recent installs by BT have gone back to the Huawei brand but not sure whether this is because of the 96 connection cabs or if its because of the 288 connection cabs...
All BDUK installs seem to have always used Huawei's cabinets in both these locations.
But please don't take my word for it... it was just an opinions based on some brief research.
Re: G.INP
01-07-2015 11:07 PM
Re: G.INP
01-07-2015 11:10 PM
Do you have anything that backs up your statement?
Re: G.INP
02-07-2015 12:30 AM
Quote from: AlecR It's because ECI cabinets don't support vectoring nor G.INP.
That's incorrect ECI cabs can do Vectoring although some may require an upgrade to make it happen, and they can do G.INP but only on the Downstream.
Re: G.INP
02-07-2015 11:52 AM
BEFORE:
Interleaved 16/8
INP 46.00/47:00
Sync 79999/20000
NOW:
Interleaved 16/1
INP 48.00/00.00
Sync 79999/19999
Re: G.INP
02-07-2015 12:11 PM
You now on Fast Path.
Re: G.INP
02-07-2015 12:26 PM
Re: G.INP
02-07-2015 1:05 PM
My connection was fast path on both downstream and upstream (1) until G.INP was enabled and then I norice m interleaving figures changed to 8 on downstream and something else on upstream...
However my ping was unaffected... I think its something to do with G.INP and it doesn't actually affect latency like before...
However if I'm wrong and it is too high then then DLM will bring it back down in time I'm sure... this mornings re-sync would have only been to remove the G.INP from DSLAM.
Re: G.INP
02-07-2015 1:10 PM
Re: G.INP
02-07-2015 1:39 PM
and regional location?
Re: G.INP
02-07-2015 2:12 PM
Copyright (c) 2009 Microsoft Corporation. All rights reserved.
C:\Windows\System32>ping bbc.co.uk
Pinging bbc.co.uk [212.58.244.20] with 32 bytes of data:
Reply from 212.58.244.20: bytes=32 time=10ms TTL=55
Ping statistics for 212.58.244.20:
Packets: Sent = 4, Received = 4, Lost = 0 (0% loss),
Approximate round trip times in milli-seconds:
Minimum = 10ms, Maximum = 10ms, Average = 10ms
Re: G.INP
02-07-2015 2:26 PM
Quote Microsoft Windows [Version 6.3.9600]
(c) 2013 Microsoft Corporation. All rights reserved.
Reply from 212.58.244.20: bytes=32 time=12ms TTL=55
Reply from 212.58.244.20: bytes=32 time=13ms TTL=55
Minimum = 12ms, Maximum = 13ms, Average = 12ms
bare in mind I'm close to edge of my WiFi coverage currently..
Re: G.INP
02-07-2015 2:44 PM
Re: G.INP
02-07-2015 5:59 PM
Re: G.INP
02-07-2015 9:37 PM
