G.INP
- G.INP
Re: G.INP
27-04-2015 7:30 PM
http://www.ispreview.co.uk/index.php/2015/04/bt-openreach-briefs-uk-fttc-fibre-broadband-isps-on-g-i...
Re: G.INP
27-04-2015 8:08 PM
Re: G.INP
27-04-2015 8:31 PM
Quote from: 11110_110 if this thread is a gold-fish bowl or a little bitch contest
Best post I've seen in this thread.
Re: G.INP
27-04-2015 9:06 PM
Quote from: tijara33
Quote this is a weakish argument.
No it isn't....................it's a FACT!!
no its pure speculation, you are speculating that if many people are unhappy they would all be posting on the forums, pure speculation.
do you work for the press? as the press love to print speculation as fact.
Re: G.INP
27-04-2015 11:02 PM
Quote from: npr
*giggle*
[tt]
/ o o \ V o o V
/ Y \ | Y |
V \ v / V \ Q /
===/___) || || (___\====
[/tt]
Troubleshooting: The Limitations of Traceroute & Ping
Latency: Connection "fast" but internet sluggish? Bufferbloat FAQ
Black Holes: Worth noting that the Plusnet Hub One router has an MTU of 1488 bytes.
Re: G.INP
28-04-2015 8:48 AM
Quote from: chrcoluk no its pure speculation, you are speculating that if many people are unhappy they would all be posting on the forums, pure speculation.
It's not a major issue - otherwise all the large ISPs would be making some kind of service statement. Similarly, the mainstream media would be reporting the issue, if it was seriously impacting the majority of internet users in the UK.
I would be surprised if 10% of FTTC users even know whether they are on Huawei or ECI kit (or even what that means).
Re: G.INP
28-04-2015 8:58 AM
Re: G.INP
28-04-2015 9:28 AM
Quote I would be surprised if 10% of FTTC users even know whether they are on Huawei or ECI kit (or even what that means).
I was until someone on here enlightened me but that doesn't take away the fact ive got a ECI modem and im on a Huawei Cabinet, and i want to know when BTO are going to upgrade the firmware because i don't see why i have to pay for a different Modem/Router just to get the best out of my Connection.
Re: G.INP
28-04-2015 10:14 AM
[tt]
==============DNS Response times various========================
Nameserver Response Time (ms)
min/avg/max/stdev/retries
192.168.0.12 1.28/1.35/1.50/0.09/0
192.168.0.15 1.96/2.01/2.06/0.04/0
212.118.241.1 11.36/12.04/12.44/0.37/0
212.118.241.33 11.20/11.46/11.78/0.24/0
83.170.64.2 11.24/11.58/11.98/0.29/0
195.12.4.247 11.81/12.16/12.55/0.26/0
212.159.13.50 15.10/15.48/15.90/0.31/0
192.168.0.254 16.40/16.58/16.87/0.19/0
8.8.8.8 11.62/11.99/12.29/0.23/0
8.8.4.4 11.66/12.21/12.70/0.36/0
4.2.2.1 11.21/11.95/12.35/0.43/0
4.2.2.6 11.95/12.27/12.52/0.22/0
208.67.222.220 11.20/11.60/11.96/0.29/0
208.67.222.222 11.46/11.78/12.14/0.26/0
==============Ping Response times bbc.co.uk======================
Packets Pings
Host Loss% Snt Last Avg Best Wrst StDev
1. 192.168.0.254 0.0% 100 1.0 1.0 0.9 1.2 0.0
2. 195.166.130.164 0.0% 100 10.5 12.0 9.7 33.8 4.7
3. 84.93.249.81 0.0% 100 10.4 11.5 9.5 59.6 5.7
4. 195.166.129.0 0.0% 100 10.9 11.6 10.0 51.0 4.7
5. 212.58.239.6 0.0% 100 10.8 10.8 9.7 15.4 0.8
6.
7.
8. 132.185.254.109 0.0% 99 12.8 11.6 10.3 21.6 1.6
9. 132.185.255.149 0.0% 99 11.2 11.8 10.7 15.1 0.7
10. 212.58.244.20 0.0% 99 10.1 10.7 10.1 12.0 0.4
===================Modem Profile================================
xdslcmd configure --phyReXmt 3
Stats recorded 28 Apr 2015 09:50:18
DSLAM/MSAN type: BDCM:0xa41b / v0xa41b
Modem/router firmware: AnnexA version - A2pv6C038m.d24j
DSL mode: VDSL2 Profile 17a
Status: Showtime
Uptime: 1 day 22 hours 1 min 23 sec
Resyncs: 0 (since 28 Apr 2015 09:50:14)
Downstream Upstream
Line attenuation (dB): 24.5 0.0
Signal attenuation (dB): Not monitored
Connection speed (kbps): 43999 6832
SNR margin (dB): 7.7 6.3
Power (dBm): 11.2 1.4
Interleave depth: 16 4
INP: 47.00 43.00
G.INP: Enabled
RSCorr/RS (%): 0.0098 1.3218
RSUnCorr/RS (%): 0.0000 0.0000
ES/hour: 0 0[/tt]
xdslcmd info --stats
xdslcmd: ADSL driver and PHY status
Status: Showtime
Retrain Reason: 0
Last initialization procedure status: 0
Max: Upstream rate = 7037 Kbps, Downstream rate = 47692 Kbps
Bearer: 0, Upstream rate = 6832 Kbps, Downstream rate = 43999 Kbps
Bearer: 1, Upstream rate = 0 Kbps, Downstream rate = 0 Kbps
Link Power State: L0
Mode: VDSL2 Annex B
VDSL2 Profile: Profile 17a
TPS-TC: PTM Mode(0x0)
Trellis: U:ON /D:ON
Line Status: No Defect
Training Status: Showtime
Down Up
SNR (dB): 7.7 6.3
Attn(dB): 24.5 0.0
Pwr(dBm): 11.2 1.4
VDSL2 framing
Bearer 0
MSGc: -6 -6
B: 150 211
M: 1 1
T: 0 0
R: 8 10
S: 0.1089 0.9856
L: 11681 1802
D: 16 4
I: 159 222
N: 159 222
Q: 16 4
V: 9 1
RxQueue: 28 12
TxQueue: 14 6
G.INP Framing: 18 18
G.INP lookback: 14 6
RRC bits: 24 24
Bearer 1
MSGc: 90 58
B: 0 0
M: 2 2
T: 2 2
R: 16 16
S: 10.6667 16.0000
L: 24 16
D: 1 1
I: 32 32
N: 32 32
Q: 0 0
V: 0 0
RxQueue: 0 0
TxQueue: 0 0
G.INP Framing: 0 0
G.INP lookback: 0 0
RRC bits: 0 0
Counters
Bearer 0
OHF: 0 0
OHFErr: 0 0
RS: 1775935088 3300798
RSCorr: 173859 30756
RSUnCorr: 0 0
Bearer 1
OHF: 10329587 933006
OHFErr: 0 2
RS: 61977152 2826054
RSCorr: 34 100
RSUnCorr: 0 0
Retransmit Counters
rtx_tx: 50777 8129
rtx_c: 41005 8853
rtx_uc: 2744 188
G.INP Counters
LEFTRS: 653 572
minEFTR: 43998 6827
errFreeBits: 134417208 370046168
Bearer 0
HEC: 0 0
OCD: 0 0
LCD: 0 0
Total Cells: 1154038671 0
Data Cells: 355828917 0
Drop Cells: 0
Bit Errors: 0 0
Bearer 1
HEC: 0 0
OCD: 0 0
LCD: 0 0
Total Cells: 0 0
Data Cells: 0 0
Drop Cells: 0
Bit Errors: 0 0
ES: 35 11
SES: 1 0
UAS: 126 126
AS: 165924
Bearer 0
INP: 47.00 43.00
INPRein: 0.00 0.00
delay: 0 0
PER: 0.00 0.00
OR: 0.01 0.01
AgR: 44200.44 6856.53
Bearer 1
INP: 2.50 4.00
INPRein: 2.50 4.00
delay: 0 0
PER: 16.06 16.06
OR: 47.81 31.87
AgR: 47.81 31.87
Bitswap: 106982/106982 1095/1095
Total time = 1 days 20 hours 25 min 14 sec
FEC: 2463533 331507
CRC: 97 27
ES: 35 11
SES: 1 0
UAS: 126 126
LOS: 0 0
LOF: 0 0
LOM: 0 0
Latest 15 minutes time = 10 min 14 sec
FEC: 27 0
CRC: 0 0
ES: 0 0
SES: 0 0
UAS: 0 0
LOS: 0 0
LOF: 0 0
LOM: 0 0
Previous 15 minutes time = 15 min 0 sec
FEC: 184 4
CRC: 0 0
ES: 0 0
SES: 0 0
UAS: 0 0
LOS: 0 0
LOF: 0 0
LOM: 0 0
Latest 1 day time = 20 hours 25 min 14 sec
FEC: 45722 13203
CRC: 0 0
ES: 0 0
SES: 0 0
UAS: 0 0
LOS: 0 0
LOF: 0 0
LOM: 0 0
Previous 1 day time = 24 hours 0 sec
FEC: 127265 17547
CRC: 0 0
ES: 0 0
SES: 0 0
UAS: 0 0
LOS: 0 0
LOF: 0 0
LOM: 0 0
Since Link time = 1 days 22 hours 5 min 23 sec
FEC: 173859 30756
CRC: 0 0
ES: 0 0
SES: 0 0
UAS: 0 0
LOS: 0 0
LOF: 0 0
LOM: 0 0
Re: G.INP
28-04-2015 10:40 AM
Everyone in fact agrees that the end of the world is not nigh, I do believe.
That isn't the crux of the matter.
Let's keep it to the tech.
Re: G.INP
28-04-2015 11:40 AM
I’ll look again tomorrow, same tests.
[tt]
192.168.0.12 1.30/1.35/1.49/0.07/0
192.168.0.15 1.95/2.02/2.11/0.07/0
212.118.241.1 17.29/17.69/18.08/0.28/0
212.118.241.33 17.35/17.90/18.26/0.31/0
83.170.64.2 17.03/17.33/17.70/0.25/0
195.12.4.247 17.51/17.58/17.69/0.07/0
212.159.13.50 20.39/20.87/21.26/0.34/0
192.168.0.254 21.19/22.83/28.15/2.66/0
8.8.8.8 17.23/17.57/18.09/0.31/0
8.8.4.4 17.20/17.61/17.86/0.25/0
4.2.2.1 17.63/18.56/21.29/1.37/0
4.2.2.6 17.67/18.15/18.60/0.31/0
208.67.222.220 16.94/17.41/17.70/0.26/0
208.67.222.222 16.91/17.17/17.65/0.27/0
Packets Pings
1. 192.168.0.254 0.0% 104 1.0 1.0 0.9 1.3 0.0
2. 195.166.128.187 0.0% 104 17.0 19.6 16.0 75.9 7.9
3. 212.159.2.182 0.0% 104 16.1 17.1 15.7 59.0 4.6
4. 212.159.0.214 0.0% 104 16.4 17.9 15.7 57.9 6.6
5. 195.166.129.2 0.0% 104 17.1 19.5 16.1 67.6 7.9
6. 195.166.129.4 0.0% 104 56.5 18.2 15.8 56.5 6.9
7. 212.58.239.6 0.0% 104 16.7 16.6 15.8 21.1 0.7
8.
9.
10. 132.185.254.109 0.0% 104 17.2 17.2 16.2 24.8 1.5
11. 132.185.255.149 0.0% 104 17.2 17.5 16.7 22.9 0.7
12. 212.58.244.20 0.0% 103 16.7 16.5 15.8 17.1 0.3
[/tt]
Edit: I'm on a 40/20 Profile.
I gained 2mbps in upload after G.INP was enabled, I think it's too early to tell as yet, lets see what happens over the next few days.
What I expect to happen is my Downstream to move to around 35.5mbps and for my jitter to decrease.
Re: G.INP
28-04-2015 11:44 AM
Sorry, upload seems to have reduced a little.
Are you on 40/20 @11110_110? That could 'mask' any change in sync as you were previously over 40Mb/s.
[Edit1] added 40/20 question.
[Edit2] noted slight reduction in measured upload
Re: G.INP
28-04-2015 11:51 AM
In their opinion if this was rolled out to ECI cabs and gave a 8/16ms jump in latency, then all end users can exit their contract penalty free.
I have asked for it in writing, when it comes I can scan it.
The way andyh seems to think a company can change anything and as long as the customer doesnt notice its all ok.
Re: G.INP
28-04-2015 11:56 AM
Quote from: w23 So, in very simple terms, business as usual except (very roughly) ~7ms increase on pings suggesting interleaving in one direction.
I get a marked reduction in sync speed in addition, which is indeed masked by the 40/20 product cap in my case, but is shown in the BT IP profile.
Re: G.INP
03-05-2015 9:40 AM
My line had dropped from a solid 73Mb/s 9ms Download speed (77Mb/s on the Plusnet site) to 63MB/s 15ms (65Mb/s on the Plusnet site) a few months ago. I put it down to crosstalk at the time, but was somewhat peeved.
After checking the forum recently and reading this thread I decided check my cabinet vendor and then to obtain a Huawei HG612 modem. I install the B030SP08 unlocked firmware and waited.
Nothing changed for 3 days, but I noticed on the 3rd day that the Plusnet site had upped back to 77Mb/s and I disconnected and reconnected at the router.
I am now back to where I was with a 73Mb/s 8ms Download speed.
