G.INP
- G.INP
Re: G.INP
06-02-2015 3:38 AM
- Downstream interleaving matrix of 4x238 = 952
- Downstream FEC overhead of 10 bytes per 238 bytes = 4%
- Upstream interleaving matrix of 4x163 = 652
- Upstream FEC overhead of 16 bytes per 163 bytes = 10%
Compared with npr:
- Downstream interleaving matrix of 473x64 = 30,272
I'd guess that DLM has indeed intervened using G.INP for FortKnox - these figures are wildly different from a "normal" intervention. It is a guess as to what everything means though, as no-one has a lot of experience interpreting these things.
Do you have the lower half of the Netgear page? I'm looking specifically for the sections about bearer 1 and the section containing INP, INPrein and delay.
Using FTTC since 2011. Currently on 80/20 Unlimited Fibre Extra.
Re: G.INP
06-02-2015 8:51 AM
Re: G.INP
07-02-2015 12:50 AM
Re: G.INP
07-02-2015 1:10 AM
Quote xdslcmd info --stats
xdslcmd: ADSL driver and PHY status
Status: Showtime
Retrain Reason: 1
Last initialization procedure status: 0
Max: Upstream rate = 38593 Kbps, Downstream rate = 103048 Kbps
Bearer: 0, Upstream rate = 20000 Kbps, Downstream rate = 79999 Kbps
Bearer: 1, Upstream rate = 0 Kbps, Downstream rate = 0 Kbps
Link Power State: L0
Mode: VDSL2 Annex B
VDSL2 Profile: Profile 17a
TPS-TC: PTM Mode(0x0)
Trellis: U:ON /D:ON
Line Status: No Defect
Training Status: Showtime
Down Up
SNR (dB): 12.3 17.9
Attn(dB): 12.3 0.0
Pwr(dBm): 13.6 1.9
VDSL2 framing
Bearer 0
MSGc: -6 -6
B: 130 97
M: 1 1
T: 0 0
R: 8 8
S: 0.0518 0.1554
L: 21468 5457
D: 16 8
I: 139 106
N: 139 106
Q: 16 8
V: 14 2
RxQueue: 60 39
TxQueue: 20 13
G.INP Framing: 18 18
G.INP lookback: 20 13
RRC bits: 24 24
Bearer 1
MSGc: 186 58
B: 0 0
M: 2 2
T: 2 2
R: 16 16
S: 5.3333 16.0000
L: 48 16
D: 3 1
I: 32 32
N: 32 32
Q: 0 0
V: 0 0
RxQueue: 0 0
TxQueue: 0 0
G.INP Framing: 0 0
G.INP lookback: 0 0
RRC bits: 0 0
Counters
Bearer 0
OHF: 0 0
OHFErr: 0 0
RS: 2734095472 528284
RSCorr: 24893 6707
RSUnCorr: 0 0
Bearer 1
OHF: 47402272 401648
OHFErr: 0 0
RS: 568826521 1371711
RSCorr: 3 6
RSUnCorr: 0 0
Retransmit Counters
rtx_tx: 1326 138
rtx_c: 1185 125
rtx_uc: 0 0
G.INP Counters
LEFTRS: 9 2
minEFTR: 79999 19997
errFreeBits: 929025460 232226050
Bearer 0
HEC: 0 0
OCD: 0 0
LCD: 0 0
Total Cells: 1173293021 0
Data Cells: 4255707463 0
Drop Cells: 0
Bit Errors: 0 0
Bearer 1
HEC: 0 0
OCD: 0 0
LCD: 0 0
Total Cells: 0 0
Data Cells: 0 0
Drop Cells: 0
Bit Errors: 0 0
ES: 1135 97
SES: 22 0
UAS: 328 306
AS: 761402
Bearer 0
INP: 48.00 47.00
INPRein: 0.00 0.00
delay: 0 0
PER: 0.00 0.00
OR: 0.01 0.01
AgR: 80614.82 20102.08
Bearer 1
INP: 4.00 4.00
INPRein: 4.00 4.00
delay: 3 0
PER: 16.06 16.06
OR: 95.62 31.87
AgR: 95.62 31.87
Bitswap: 570441/570442 632/634
Total time = 1 days 28 min 47 sec
FEC: 24893 6707
CRC: 0 0
ES: 1135 97
SES: 22 0
UAS: 328 306
LOS: 2 0
LOF: 19 0
LOM: 0 0
Latest 15 minutes time = 13 min 47 sec
FEC: 24 0
CRC: 0 0
ES: 0 0
SES: 0 0
UAS: 0 0
LOS: 0 0
LOF: 0 0
LOM: 0 0
Previous 15 minutes time = 15 min 0 sec
FEC: 30 2
CRC: 0 0
ES: 0 0
SES: 0 0
UAS: 0 0
LOS: 0 0
LOF: 0 0
LOM: 0 0
Latest 1 day time = 28 min 47 sec
FEC: 54 2
CRC: 0 0
ES: 0 0
SES: 0 0
UAS: 0 0
LOS: 0 0
LOF: 0 0
LOM: 0 0
Previous 1 day time = 24 hours 0 sec
FEC: 2558 142
CRC: 0 0
ES: 0 0
SES: 0 0
UAS: 0 0
LOS: 0 0
LOF: 0 0
LOM: 0 0
Since Link time = 8 days 19 hours 30 min 1 sec
FEC: 24893 6707
CRC: 0 0
ES: 0 0
SES: 0 0
UAS: 0 0
LOS: 0 0
LOF: 0 0
LOM: 0 0
HELLO HG612
xdslcmd info --pbParams
Status: Showtime
Retrain Reason: 1
Discovery Phase (Initial) Band Plan
US: (7,32) (871,1205) (1972,2782)
DS: (33,859) (1216,1961) (2793,3959)
Medley Phase (Final) Band Plan
VDSL Port Details Upstream Downstream
Attainable Net Data Rate: 38593 kbps 103048 kbps
Actual Aggregate Tx Power: 1.9 dBm 13.6 dBm
VDSL Band Status U0 U1 U2 U3 U4 D1 D2 D3
Line Attenuation(dB): 4.6 15.0 20.4 N/A N/A 7.6 17.6 26.0
Signal Attenuation(dB): 4.6 14.1 19.5 N/A N/A 9.5 17.4 26.0
SNR Margin(dB): 18.0 17.9 17.9 N/A N/A 12.3 12.3 12.3
TX Power(dBm): -12.3 -28.6 1.8 N/A N/A 10.8 7.8 6.9
Good Bye HG612
However my pings seems to be the same as seen here; if i am correct being on interleave you most likely would not see pings under 20?
Quote C:\Users\>tracert google.co.uk
Tracing route to google.co.uk [216.58.210.35]
over a maximum of 30 hops:
1 <1 ms <1 ms <1 ms router.asus.com
2 17 ms 16 ms 16 ms lo0.10.Central10.ptw-bng02.plus.net [195.166.130
.203]
3 20 ms 16 ms 15 ms irb.10.PTW-CR02.plus.net [84.93.249.2]
4 16 ms 16 ms 16 ms 72.14.223.32
5 16 ms 16 ms 15 ms 209.85.252.188
6 16 ms 16 ms 16 ms 72.14.238.21
7 16 ms 17 ms 16 ms lhr14s23-in-f3.1e100.net [216.58.210.35]
Trace complete.
Was wondering if you guys that know more about line stats could tell me what you think? THanks.
Re: G.INP
07-02-2015 9:48 AM
It's reassuring to know your ping times have not gone up but as you were on fastpath before I would guess G.INP is not working very hard on your line.
I assume that's from a unlocked HG612 modem?
Re: G.INP
07-02-2015 12:35 PM
If anyone was wondering which firmware its running with G.INP actually working (that's unlocked) i'm running V100R001C01B030SP08 made by H-WOLF.
I did try looking around too npr but as you said no one really knows at the moment with G.INP. I'm not bothered anyway what the interleaving / fast path says on the modem as long as its not increasing my pings. Which it does not seem to be.
Re: G.INP
07-02-2015 1:18 PM
the command xdslcmd info --version will show it.
eg my router uses 039e:
ADSL PHY: AnnexA version - A2pv6F039e.d24h
I wouldn't be concerned that the stats show a very small interleaving depth, it's a different system which I don't think related to interleaving as we know it.
I'm looking forward to seeing it on my line, hoping it will reduce some of the impact of aluminium cables.
Have a look at this link if you're looking for more reading on this:
http://forum.kitz.co.uk/index.php?topic=14867.0
Re: G.INP
07-02-2015 1:26 PM
Thanks ill take a look at the link
Re: G.INP
07-02-2015 1:32 PM
I'm using the Huawei modem so can check stats etc, and can only see INP = 3.
Re: G.INP
07-02-2015 1:55 PM
In the above stats posted by carlmagic, look for:
"G.INP Framing: 18 18"
"G.INP lookback: 20 13"
Not sure of the significance of the numbers yet, but it appears to only show when G.INP is active.
also
"Bearer 1"
Bearer 0 is the standard connection, Bearer 1 is the path used by G.INP and is only shown when G.INP is active.
also a less convincing indication.
look at the interleave depth for Bearer 0
😧 16 8
A small number (>1 but <100's) appears to indicate G.INP may be active.
Re: G.INP
08-02-2015 7:31 PM
Re: G.INP
11-02-2015 9:17 PM
Thanks to carlmagic's assistance & testing etc. I now have HG612 Modem Stats working both with G.INP enabled & G.INP not enabled connections & am busy writing the code to graph these new/additional stats.
It is not enabled on my connection, so it's a bit of a slow process to get it right as I can't test anything immediately.
At the moment, I'm concentrating on the Huawei HG612, but the code for modems such as Billion & ZyXel will also follow in due course.
Re: G.INP
11-02-2015 9:29 PM
Re: G.INP
12-02-2015 12:26 AM
Re: G.INP
12-02-2015 9:59 PM
Quote from: npr Does anyone know if DSLstats v5.3 support G.INP ?
It doesnt report any of the G.INP values. Its also showing my connection as interleaved when really its running G.INP. So its not supported properly. However other features still work.
