G.INP
- Re: G.INP
- « Previous
- Next »
Re: G.INP
30-08-2015 9:45 AM
Re: G.INP
30-08-2015 10:23 AM
Quote from: AndyH
Quote from: Terranova667 There is no date for the ECI rollout at present, Kitz had a talk with a high up at openreach he said "The issue here is that some of our field test equipment requires new firmware to work with retransmission across our ECI estate. As soon as we are comfortable with the stability of this firmware, we will begin the rollout of retransmission across the ECI DSLAMs As soon as we have an update on our plans for the ECI rollout we will let you and the industry know".
The handheld tester issue was fixed a couple of months ago and the migration glidepath for ECI was published to working group members in mid Aug.
I think someone very high up ie Ian Lawrence the chief engineer which is who Kitz talked to would know what the current situation is
Re: G.INP
30-08-2015 10:50 AM
Quote from: Terranova667 I think someone very high up ie Ian Lawrence the chief engineer which is who Kitz talked to would know what the current situation is
That's great, but he's clearly out if the loop with the up-to-date things. I suggest he talks to Paul Sadd or Phil Everett.
Re: G.INP
30-08-2015 1:05 PM
Re: G.INP
30-08-2015 6:22 PM
Re: G.INP
30-08-2015 6:32 PM
Quote from: chrcoluk more likely he held things back due to having his name put on the publication.
There is nothing preventing any ISP (that has been briefed) on publishing the rollout schedule for retransmission on ECI cabs/lines. It won't be very informative though as it will just say starts on X date and schedule to be completed by X date.
Edit: I should add, I would be very surprised if any ISP publishes any information about the ECI retransmission rollout.
Re: G.INP
30-08-2015 6:49 PM
Re: G.INP
30-08-2015 9:15 PM
Are there any examples of an ECI modem supporting both down/upstream retransmission on non-ECI cabs in other countries at the moment?
Interesting how you only see Broadcom based devices approved in Openreach's modem testing (always BCM63168 chipset).
Re: G.INP
30-08-2015 9:28 PM
Quote from: AndyH
HomeHub 5 type A and ECI modem aren't Broadcom, are they not approved.
Re: G.INP
30-08-2015 9:50 PM
Quote from: JasonMassey
Quote from: JasonMassey G.INP has just been removed on the UPSTREAM.
Just to summarize.
First G.INP was downstream only
Then it was downstream and upstream
Then it was downstream only
Now is it downstream only.
All above is despite having a Draytek 2860n with full support for G.INP down and up, and having perfect stable connection when working.
Just to add, yesterday G.INP on upstream was re-enabled.
Just to add, today G.INP on upstream has been disabled.
I make this 7 G.INP changes in total so far.
Re: G.INP
30-08-2015 10:00 PM
Quote from: npr HomeHub 5 type A and ECI modem aren't Broadcom, are they not approved.
Ah...sorry, I meant other modems that had been through the Openreach testing. I suppose the upstream retransmission optionality in the SIN is due to the lack of support from some chipsets.
- « Previous
- Next »
