G.INP
- Re: G.INP
Re: G.INP
23-07-2015 1:26 PM
Think you might of posted that in the wrong place?
Re: G.INP
23-07-2015 5:08 PM
Quote from: Estragon
Quote from: supernova1 G.IMP'e last night.
G.INP Framing: 18 0
G.INP lookback: 26 0
Notice anything?
Nope, I give up, what's the answer
ATB
SN
Re: G.INP
23-07-2015 6:00 PM
Quote from: NoZephy @chrcoluk
ok wtf
thanks for alerting me anyhow.
Re: G.INP
24-07-2015 9:50 AM
So not sure why that would be.
The brief history is...
1) G.Inp got applied to US and DS
2) G.Inp got removed from US but stayed on DS
3) G.Inp returned to US
4) G.Inp has been removed from US again.
This is a Huawei cabinet with HG612 modem.
I think I have dropped about 2Mbps from the upload speed as a result of the removal from US.
What will happen next I wonder.
Re: G.INP
24-07-2015 10:11 AM
Re: G.INP
24-07-2015 12:18 PM
Re: G.INP
24-07-2015 2:18 PM
As you said jafreer, it will be interesting as to what happens next, i.e. if the error rate reaches the threshold, will it apply G.INP again or apply interleaving.
Re: G.INP
24-07-2015 7:46 PM
The only flaw in that is if I lose upstream speed because of the change. Then there is no point in removing G.Inp because it is a detrimental change if I lose speed. Unless of course pings are better (which I haven't seen after testing). Then does that mean DLM favours a change that improves ping but reduces speed?
Maybe I need to inject some errors back in to take me off fastpath and see if G.Inp is reapplied. That would test the theory I suppose.
Re: G.INP
24-07-2015 8:05 PM
Could you post the current stats from your modem?
Re: G.INP
24-07-2015 8:10 PM
Stats recorded 24 Jul 2015 20:09:39
DSLAM/MSAN type: BDCM:0xa485 / v0xa485
Modem/router firmware: AnnexA version - A2pv6C038m.d24j
DSL mode: VDSL2 Profile 17a
Status: Showtime
Uptime: 2 days 11 hours 20 min 43 sec
Resyncs: 0 (since 24 Jul 2015 20:09:33)
Downstream Upstream
Line attenuation (dB): 22.0 0.0
Signal attenuation (dB): Not monitored
Connection speed (kbps): 45563 7576
SNR margin (dB): 6.3 6.0
Power (dBm): 11.2 -4.7
Interleave depth: 8 1
INP: 47.00 0
G.INP: Enabled
RSCorr/RS (%): 0.0623 0.0000
RSUnCorr/RS (%): 0.0000 0.0000
ES/hour: 0.07 19.9
Re: G.INP
24-07-2015 8:21 PM
Re: G.INP
24-07-2015 11:33 PM
xdslcmd info --stats
xdslcmd: ADSL driver and PHY status
Status: Showtime
Retrain Reason: 1
Last initialization procedure status: 0
Max: Upstream rate = 7576 Kbps, Downstream rate = 45724 Kbps
Bearer: 0, Upstream rate = 7576 Kbps, Downstream rate = 45563 Kbps
Bearer: 1, Upstream rate = 0 Kbps, Downstream rate = 0 Kbps
Link Power State: L0
Mode: VDSL2 Annex B
VDSL2 Profile: Profile 17a
TPS-TC: PTM Mode(0x0)
Trellis: U:ON /D:ON
Line Status: No Defect
Training Status: Showtime
Down Up
SNR (dB): 6.5 5.9
Attn(dB): 22.0 0.0
Pwr(dBm): 11.2 -4.7
VDSL2 framing
Bearer 0
MSGc: -6 26
B: 243 223
M: 1 1
T: 0 42
R: 10 0
S: 0.1705 0.9392
L: 11916 1908
D: 8 1
I: 254 112
N: 254 224
Q: 8 0
V: 0 0
RxQueue: 36 0
TxQueue: 12 0
G.INP Framing: 18 0
G.INP lookback: 12 0
RRC bits: 0 24
Bearer 1
MSGc: 122 -6
B: 0 0
M: 2 0
T: 2 0
R: 16 0
S: 8.0000 0.0000
L: 32 0
D: 1 0
I: 32 0
N: 32 0
Q: 0 0
V: 0 0
RxQueue: 0 0
TxQueue: 0 0
G.INP Framing: 0 0
G.INP lookback: 0 0
RRC bits: 0 0
Counters
Bearer 0
OHF: 0 782929
OHFErr: 4 1490
RS: 981412240 3776626
RSCorr: 447121 0
RSUnCorr: 0 0
Bearer 1
OHF: 14058894 0
OHFErr: 0 0
RS: 112470661 0
RSCorr: 23 0
RSUnCorr: 0 0
Retransmit Counters
rtx_tx: 887185 5104
rtx_c: 48599 106216
rtx_uc: 29403 32858
G.INP Counters
LEFTRS: 580 1002
minEFTR: 45564 8567
errFreeBits: 1302030748 869293275
Bearer 0
HEC: 0 0
OCD: 0 0
LCD: 0 0
Total Cells: 2606294813 0
Data Cells: 103899567 0
Drop Cells: 0
Bit Errors: 0 0
Bearer 1
HEC: 0 0
OCD: 0 0
LCD: 0 0
Total Cells: 0 0
Data Cells: 0 0
Drop Cells: 0
Bit Errors: 0 0
ES: 28 1394
SES: 11 0
UAS: 60 49
AS: 225825
Bearer 0
INP: 47.00 0.00
INPRein: 0.00 0.00
delay: 0 0
PER: 0.00 9.90
OR: 0.01 25.85
AgR: 45609.30 7602.30
Bearer 1
INP: 2.00 0.00
INPRein: 2.00 0.00
delay: 0 0
PER: 16.06 0.01
OR: 63.75 0.01
AgR: 63.75 0.01
Bitswap: 133857/133869 624/624
Total time = 1 days 5 hours 10 min 39 sec
FEC: 1954283 10564
CRC: 623 1490
ES: 28 1394
SES: 11 0
UAS: 60 49
LOS: 1 0
LOF: 10 0
LOM: 0 0
Latest 15 minutes time = 10 min 39 sec
FEC: 381 0
CRC: 0 5
ES: 0 5
SES: 0 0
UAS: 0 0
LOS: 0 0
LOF: 0 0
LOM: 0 0
Previous 15 minutes time = 15 min 0 sec
FEC: 2366 0
CRC: 0 9
ES: 0 9
SES: 0 0
UAS: 0 0
LOS: 0 0
LOF: 0 0
LOM: 0 0
Latest 1 day time = 5 hours 10 min 39 sec
FEC: 14428 0
CRC: 2 165
ES: 1 141
SES: 0 0
UAS: 0 0
LOS: 0 0
LOF: 0 0
LOM: 0 0
Previous 1 day time = 24 hours 0 sec
FEC: 100083 0
CRC: 2 496
ES: 1 471
SES: 0 0
UAS: 0 0
LOS: 0 0
LOF: 0 0
LOM: 0 0
Since Link time = 2 days 14 hours 43 min 43 sec
FEC: 447121 0
CRC: 4 1490
ES: 2 1394
SES: 0 0
UAS: 0 0
LOS: 0 0
LOF: 0 0
LOM: 0 0
Re: G.INP
25-07-2015 2:08 AM
You say G.IMP. It isn't :).
Quote from: supernova1 Nope, I give up, what's the answer
ATB
SN
It's G.INP.
Re: G.INP
25-07-2015 9:06 AM
Re: G.INP
25-07-2015 1:50 PM
