G.INP
- Re: G.INP
Re: G.INP
18-07-2015 12:14 PM
Re: G.INP
18-07-2015 3:26 PM
Quote from: Stoker Following a fault last week I had a lift&shift and DLM reset., and no longer have G.IMP enabled. I have an (unlocked) Huawei modem and am on a Huawei cabinet. G.IMP was enabled before the problem.
Can PlusNet enable it through profiles or do I have to wait for BTOR?
Interleave depth: 13 5
INP: 0 0
G.INP: Not enabled
The same happened to me, over 60 days ago. I had G.INP them after Lift&shift + DLM Reset, no more G.INP !!!
It has just been re-enabled with G.INP ver 2, as it seems to be called.
i.e. G.INP on DS only.
It will come back of its own accord but the timing is another of the Great Openreach mysteries we have to endure.
Re: G.INP
20-07-2015 7:58 AM
Re: G.INP
20-07-2015 11:22 AM
Hmm. Thoughts?
Re: G.INP
20-07-2015 11:44 AM
Without G.INP I'd have suggested that you may have more errors at the higher speed reducing your throughput due to retransmission being necessary but with G.INP I thought that didn't happen (not on the main bearer anyway). Even if the Plusnet Profile hasn't caught up I can't see how that would reduce speed. Maybe you've just randomly hit a poorer performing gateway - try disconnecting your router (not the modem) to see if a different gateway changes things.
Re: G.INP
20-07-2015 5:59 PM
Re: G.INP
21-07-2015 11:44 AM
Re: G.INP
22-07-2015 6:42 PM
I was one of the first connected to my cab in April with max atainlable about 88Mbps and missed G.IMP v1
Over last 3 months x-talk reduced my sync to 76Mbps.
BUT now with G.IMPv2 active on my line max atainable is 81Mbps
Also ping has reduced from 16ms to 10ms.
An increase of about 5mbps and reduction in ping ......Haaaaapyyyy
ATB
SN
Max: Upstream rate = 29691 Kbps, Downstream rate = 80364 Kbps
Bearer: 0, Upstream rate = 19999 Kbps, Downstream rate = 80000 Kbps
Bearer: 1, Upstream rate = 0 Kbps, Downstream rate = 0 Kbps
Link Power State: L0
Mode: VDSL2 Annex B
VDSL2 Profile: Profile 17a
TPS-TC: PTM Mode(0x0)
Trellis: U:ON /D:ON
Line Status: No Defect
Training Status: Showtime
Down Up
SNR (dB): 6.2 15.2
Attn(dB): 12.0 0.0
Pwr(dBm): 13.8 1.3
VDSL2 framing
Bearer 0
MSGc: -6 26
B: 203 237
M: 1 1
T: 0 42
R: 10 16
S: 0.0809 0.3781
L: 21153 5374
D: 8 1
I: 214 127
N: 214 254
Q: 8 0
V: 5 0
RxQueue: 78 0
TxQueue: 26 0
G.INP Framing: 18 0
G.INP lookback: 26 0
RRC bits: 0 24
Bearer 1
MSGc: 186 -6
B: 0 0
M: 2 0
T: 2 0
R: 16 0
S: 5.3333 0.0000
L: 48 0
D: 3 0
I: 32 0
N: 32 0
Q: 0 0
V: 0 0
RxQueue: 0 0
TxQueue: 0 0
G.INP Framing: 0 0
G.INP lookback: 0 0
RRC bits: 0 0
Counters
Bearer 0
OHF: 0 1155665
OHFErr: 0 43
RS: 1712395464 2312051
RSCorr: 10591 592
RSUnCorr: 0 0
Bearer 1
OHF: 7596949 0
OHFErr: 0 0
RS: 91162646 0
RSCorr: 0 0
RSUnCorr: 0 0
Retransmit Counters
rtx_tx: 155 0
rtx_c: 155 0
rtx_uc: 0 0
G.INP Counters
LEFTRS: 1 0
minEFTR: 79983 0
errFreeBits: 148871705 0
Bearer 0
HEC: 0 0
OCD: 0 0
LCD: 0 0
Total Cells: 1593248738 0
Data Cells: 48918376 0
Drop Cells: 0
Bit Errors: 0 0
Bearer 1
HEC: 0 0
OCD: 0 0
LCD: 0 0
Total Cells: 0 0
Data Cells: 0 0
Drop Cells: 0
Bit Errors: 0 0
ES: 3593 1217
SES: 31 0
UAS: 63 53
AS: 122028
Re: G.INP
22-07-2015 7:45 PM
Re: G.INP
22-07-2015 9:18 PM
I forgot to mention,
Previous I was on fast path / no interleaving or G.IMPv1 so the improvement is due to G.IMPv2 and not because I was interleaved / running broken G.IMPv1 thats now been fixed.
I thought I might see at best 1 or 2mbps increase, so very happy that I'm back up to the magic 80mbs.
The SNMR is the same at 6.1db
Hope it works for you too.
ATB
SN
Re: G.INP
22-07-2015 11:18 PM
Quote from: supernova1 G.IMP'e last night.
G.INP Framing: 18 0
Notice anything?
Re: G.INP
23-07-2015 12:53 AM
Quote from: Estragon Instead of all the hassle of interleaving, which is considerable on FTTC because of the high speeds, little if any interleaving is then applied. Instead of error correction, which is what interleaving is used for, duff packets are simply re-transmitted on Bearer 1, without interrupting the main Bearer 0.
That's what we used to think.
After investigation, it looks like bearer 1 only carries an overhead channel, with status information being passed back and forth between modems. This bearer keep old-style FEC+interleaving protection (even more aggressive than standard DLM), without retransmission.
The main end-user data stream is carried in bearer 0 - both the original blocks as well as any retransmitted ones.
In old-style DLM intervention, the FEC+interleaving settings were harsh - causing 8ms or 16ms latency delays, and using up to 20% of the bandwidth,
In new-style DLM intervention (which happens to almost all lines now (edit: well, Huawei-cabinet lines, anyway) beyond the initial DLM reset period), retransmission through G.INP is the mainstay. However, FEC+interleaving remain in use, but with much less aggressive settings: around 0.2ms delay, and around 5% of bandwidth.
Using FTTC since 2011. Currently on 80/20 Unlimited Fibre Extra.
Re: G.INP
23-07-2015 1:42 AM
Re: G.INP
23-07-2015 6:58 AM
Bearer 0 Interleaving depth Is 8 for DS & 1 for US.
Along with the rtx retransmissions, RSCorr/FEC is fairly active on Bearer 0 & a slight amount can be seen on Bearer 1.
Re: G.INP
23-07-2015 12:19 PM
