G.INP
- Re: G.INP
Re: G.INP
03-07-2015 7:52 AM
I thought the whole point of having G.INP was so you could have the error correction but without the ping increases of standard interleaving that we've had to put up with for years now
Re: G.INP
03-07-2015 11:38 PM
It worked flawless for months for me, now I see more line errors, but no disconnects. Total [Censored] fail.
dick:quote
Re: G.INP
03-07-2015 11:47 PM
Imagine if they'd taken the same approach with ADSL2+, some modems only work on ADSL(1), so we'd better reverse the upgrade.
Re: G.INP
04-07-2015 12:11 AM
Unfortunately we can only speculate why OR decided to kill it on all lines instead of just ECI's... also no one is sure whether it will still be applied to lines (activate since)
Openreach don't make this information public and I don't think they even tell ISP's...
I would think they would bring it back in... whether it be with better capability or they sort the system out so that the correct profiles are assigned to lines with the appropriate equipment.
So if a DSLAM identifies a compatible Broadcom chip in a modem then it activates both upstream and downstream with ReTX profiles, if it picks Lantiiqs chip from ECI or HH5 then it applies ReTX to downstream and fast path/Interleaving to upstream and anything else not in in the capable datebase gets standard fast path and interleaving profiles..
But I think the system in use to do mass profile switching such as the one currently disabling G.INP (Upstream) will need some tweaking so it can only select a certain group of lines or equipment...
Re: G.INP
04-07-2015 8:57 AM
Re: G.INP
04-07-2015 8:21 PM
Re: G.INP
05-07-2015 10:55 PM
Quote from: w23 Imagine if they'd taken the same approach with ADSL2+, some modems only work on ADSL(1), so we'd better reverse the upgrade.
I was going to say something very similar in my last message but decided to omit it
"Guys, it's not fair that some people are able to connect to 21CN and use ADSL2+ and get better speeds on shorter lines so let's just remove it completely and go back to ADSL1. Heck, let's just go back all the way to dialup and make it fair for everyone"
/s
Re: G.INP
06-07-2015 10:07 AM
The only way to improve the system involves a massive investment and BT is too short sighted in it's outlook to consider it.
Re: G.INP
10-07-2015 10:02 AM
Quote from: AndyH As of 9/10 June, they had migrated 935k lines over to the new profile. They can do 50-60k lines a day and there are some 4.5 million Huawei lines, so I would say they are about half way through now. I'll get the updated figures next week.
Have you got new figures, out of interest?
Re: G.INP
11-07-2015 2:29 AM
No more 8ms latency on the downstream and I've gone from a 69,000/19,000 sync to a 79,999/20,000 sync
(pic attached, note the INP @ 49.00 instead of 3.00)
Here's some speedtest for anyone interested in the improvements on my line. Included some thinkbroadband tests for the people who take issue with speedtest's "inaccuracies"
Also I decided to test it out in a real download, so I booted up Steam and took a screenshot. Needless to say I'm impressed with G.INP so far. (Attachment)
Also just to confirm, my fibre service was activated AFTER G.INP v1.0 was put on hold and they paused the rollout. So @Cornholio you can take this post as confirmation that the rollout of G.INP v2.0 is actually in the works on lines that have never had any sort of G.INP on them before
Without G.INP:
With G.INP:
Re: G.INP
11-07-2015 11:24 AM
Re: G.INP
11-07-2015 3:58 PM
However, my speed stayed the same as it was after the second fix - 63Mbps and well below what I had before G.INP - 74Mbps.
Am I now being artificially restricted or the speed should return back to what it was before soon?
Re: G.INP
12-07-2015 12:08 AM
Quote from: AndyH Not sure who quoted the 50%...
I said it on the 19th of June, which was the day after I'd had a conversation with someone very high up at Openreach who knew the exact figures at that date.
Quote from: NoZephy Just thought I'd write an update if anyone is interested, my line is now G.INP active!
Thanks for that confirmation. I'd also previously said that the 'catchups' should commence once all the g.inp Mk1s -> Mk2's have been done
Re: G.INP
12-07-2015 12:43 AM
Re: G.INP
12-07-2015 9:44 AM
When I've been mk2 d, I'll post before and after stats.
At
SN
