G.INP
- Re: G.INP
Re: G.INP
13-02-2015 12:16 AM
However, the raw stats show this:-
Bearer 0
D: 16 8 **** Usually indicates Interleaving depth ****
Bearer 1
D: 3 1 **** Usually indicates Interleaving depth ****
Counters
Bearer 0
OHF: 0 0
OHFErr: 0 0
RS: 3492152688 101622
RSCorr: 9832 799
RSUnCorr: 0 0
Bearer 1
OHF: 30635268 345861
OHFErr: 0 0
RS: 367622475 2759176
RSCorr: 3 1
RSUnCorr: 0 0
Retransmit Counters
rtx_tx: 2218 43
rtx_c: 638 294
rtx_uc: 0 41690
Bearer 0
INP: 48.00 47.00 **** These seem to be very high values ******
INPRein: 0.00 0.00
delay: 0 0
PER: 0.00 0.00
OR: 0.01 0.01
AgR: 80614.82 20102.08
Bearer 1
INP: 4.00 4.00
INPRein: 4.00 4.00
delay: 3 0
PER: 16.06 16.06
OR: 95.62 31.87
AgR: 95.62 31.87
It certainly suggests that some type of interleaving is applied.
I'm not sure whether G.INP replaces Interleaving or supplements it, allowing lower interleaving depths & fewer negative speed/delay effects
All will no doubt become clearer once we can see stats from other users' connections, particularly those from poorer quality and/or lower speed connections..
FWIW, Roseway, the DSLStats program author is waiting until I have fine tuned HG612 Modem Stats to fully accommodate these new stats before he carries out any major updates to DSLStats.
I hope to have my updates more or less completed over this weekend or early next week.
Re: G.INP
13-02-2015 6:28 AM
However I don't feel like interleave is actually running as i mentioned before that my ping's have remained the same from when both modemstats and dsl stats were reporting that i was on fast path.
If a plusnet staff member sees this could it be possible for you to post what my profile is showing as on your side? thanks.
For example my speedtest showing a 15ms ping from North wales to london. (Note QOS blocks download at 70mbit)
and a ping test result
If my connection was running some kind of interleave surely these would be higher?
Re: G.INP
15-02-2015 6:51 PM
Today he notified me that the graph's function is now working (although still in BETA!) and supplied me with the graphs from the logs i had sent him and also the updated .exe for making the graph's myself.
Here are the graphs that where created using modemstats with G.INP running for those that are interested
Please note that the boarders of the graphs follow a colour code as follows:
GREEN = always present
YELLOW = Bearer 1 data & G.INP specific data
GREY = Bearer 0 data
https://mega.co.nz/#!KYd1TKTA!N3-bPRBDpgLUDxMS4yuks6fQzV2tSmVeryQnFGylAvI
Bald Eagle informed me that he is hoping the full release of the updated modem stats program will be coming soon.
Id like to thank him for the amount of work and effort he has put into it
Re: G.INP
18-03-2015 7:21 PM
DSLAM/MSAN type: BDCM:0xa41b / v0xa41b
Modem/router firmware: AnnexA version - A2pv6C038m.d24j
DSL mode: VDSL2 Profile 17a
Status: Showtime
Uptime: 12 hours 56 min 31 sec
Resyncs: 0 (since 18 Mar 2015 12:36:14)
Downstream Upstream
Line attenuation (dB): 24.3 0.0
Signal attenuation (dB): Not monitored
Connection speed (kbps): 39059 6741
SNR margin (dB): 6.0 5.6
Power (dBm): 11.1 2.2
Interleave depth: 8 4
INP: 46.00 43.00
G.INP: Enabled
RSCorr/RS (%): 0.0003 0.3128
RSUnCorr/RS (%): 0.0000 0.0000
ES/hour: 0 0
[/tt]
Re: G.INP
18-03-2015 7:22 PM
Re: G.INP
18-03-2015 7:27 PM
Re: G.INP
18-03-2015 7:28 PM
Re: G.INP
18-03-2015 7:39 PM
Re: G.INP
18-03-2015 7:41 PM
Re: G.INP
18-03-2015 7:47 PM
Re: G.INP
18-03-2015 7:53 PM
Re: G.INP
18-03-2015 7:59 PM
@ Terranova667 - It's a trade off as you get the faster speeds, but with increased latency. Not ideal for gamers though.
Re: G.INP
18-03-2015 8:01 PM
Quote from: AndyH You don't really want it enabled on your line though - it increases latency by 15-30ms.
Does it ?
Re: G.INP
18-03-2015 8:03 PM
Re: G.INP
18-03-2015 8:24 PM
