G.INP
- Re: G.INP
G.INP
28-01-2015 11:19 PM
Any way to know if we have G.INP activated on our line? Looks like it is being activated at the moment.
Cheers
Re: G.INP
29-01-2015 8:19 AM
If you think it's enabled on your line can you please post your router stats for us all to see.
Some info here http://forum.kitz.co.uk/index.php?topic=14867.0
Re: G.INP
29-01-2015 10:21 AM
someone on the CRT could run a GEA test and see if it's enabled it would say Retransmission Low/High rather than Interleaving if it's enabled ( got that from the think broadband forums)
I wouldn't mind knowing that myself, i had my ping drop early this morning from 20-24ms down to it's usual 12-15ms could simply be DLM removing interleaving or something else i dont know
Re: G.INP
29-01-2015 11:17 AM
My HG635 vdsl modem router shows PhyR is not enabled -- don't know if that gets enabled automatically if / when G.INP gets switched on. There's some confusion whether G.INP and PhyR are the same thing.
Re: G.INP
29-01-2015 11:55 AM
Quote from: npr I believe if your routers stats shows the connection to be fastpath (interleave depth = 1) together with any FEC errors then it's likely G.INP is active.
I think I had G.INP during my last fault before I had my pair swapped, was on fastpath with FEC errors on my downstream.
I posted about it on tbb at the time and I am registered on MDWS, check the period for chrysalis on date 1st week of september.
Re: G.INP
29-01-2015 3:32 PM
Quote from: Terranova667 with fibre the stats are gotten from the modem in which the BTO modems are locked down, unless you have managed to get hold of a BTO modem that has been unlocked or bought your own all in one you wont be able to see the stats yourself to see if G.INP is active.
Yeah cannot access the line stats with my router ASUS. Would need to unlock the modem itself, which I do not intend to do at the moment.
My lowest line ping latency is around 8 ms from ThinkBroadband, this has been a while like that, not sure if G.INP is on.
Re: G.INP
29-01-2015 5:36 PM
It is perfectly possible for the modems to make use of FEC correction without interleaving - they are two different processes, although their usage tends to be interlinked. There is no point in having interleaving without FEC, but there is a point in having FEC without interleaving.
I posted some analysis on one case of this near the end of that Kitz thread linked above. The stats from the modem in that case showed every indication of FEC being turned on, and no indication of G.INP being turned on. And FEC without interleaving was proving to be very effective on that line.
What we don't yet know is *why* the modems end up with FEC configured without interleaving. There is little published, and a lot of guesswork is involved in decoding what BTO are up to.
As for G.INP: I have seen one case of modem statistics that made it clear G.INP was in use - but it wasn't an HG612. That modem showed statistics for G.INP-specific things (with labels that included the text "G.INP"). It also configured the line slightly differently, where "bearer 0" was the standard data channel subject to G.INP retries. However, the modem created an additional "bearer 1" that is used by G.INP to send the re-transmitted packets. Bearer 1 was configured with low speed, but very high FEC and interleaving protection. I think this is to make sure that only a single retry is needed.
Using FTTC since 2011. Currently on 80/20 Unlimited Fibre Extra.
Re: G.INP
30-01-2015 10:46 AM
Profile Name 0.128M-80M Downstream, Error Protection Off - 0.128M-20M Upstream, Error Protection Off
That's the profile of your line currently.
@Terranova667
And here is your profile:
0.128M-60M Downstream, Error Protection Off - 0.128M-17M Upstream, Interleaving On
Re: G.INP
30-01-2015 11:54 AM
Quote from: WWWombat I think this "FEC Errors with fastpath" is a red herring, and is not a sign of G.INP being activated.
not so sure.
I remember you commented on my line at the time and we both agreed it was highly unusual, why else would openreach have profiled my line like that on DLM, it only makes sense if they were testing g.inp.
Re: G.INP
30-01-2015 1:48 PM
Re: G.INP
30-01-2015 2:05 PM
40M-80M Downstream, Error Protection Off - 10M-20M Upstream, Error Protection Off
Re: G.INP
30-01-2015 2:09 PM
Re: G.INP
30-01-2015 2:17 PM
does 0.128M-60M Downstream mean DLM has me banded down to 60Mb rather than allowing for the full 80Mb any reason for that , i'm guessing it's something that cant be done about apart from DLM choosing to remove it if it feels it's good to do so, maybe my last episode with the pusnet profile change was an attempt from DLM to remove the banding but it didn't last, hmm might give me hope another attempt could be possible as i say my ping has lowered so it could be a sign that things are looking better.
Re: G.INP
30-01-2015 2:54 PM
Re: G.INP
30-01-2015 3:05 PM
