G.INP enabled on line sync speed increased profile reset?
- G.INP enabled on line sync speed increased profile...
20-08-2017 12:27 PM
G.INP has been enabled on my line after about 2 weeks after the install and as a result my sync speed has jumped about 10Mbs Plus net is still capping my speed back to 68 though. Can this be reset, i know it can be done
Re: G.INP enabled on line sync speed increased profile reset?
20-08-2017 2:17 PM
Daft question, but how do you know if G.IMP is active on a line?
20-08-2017 2:58 PM
Not daft at all. I'm using a Openreach Huawei HG612 modem (Supplied before the hub one). You can unlock these and access detailed line information using a tool called DSL Stats (Guide can be found here: https://tinyurl.com/y92nsyd3). From here you can see if it is enabled as per the attached photo
20-08-2017 4:21 PM
Thanks for the info there.....I actually have a HG612 on order, so hopefully I will be able to keep an eye on line stats myself instead of waiting on PN to give me details.
21-08-2017 3:07 PM
@lewisp8 From what I can see the profile has increased?
Let us know if that isn't the case
21-08-2017 10:23 PM
22-08-2017 11:20 AM
I was just looking at your attached pics, the one that shows the modem stats figures there is rows that have error counts...CRC Errors, FEC Errors & HEC Errors....I see that you picture shows errors on the CRC row and also on the HEC row....is that something you need to have looked into or is that a known issue/fault with the HG612 modem firmware?
22-08-2017 12:39 PM
With downstream G.inp active (retransmission high) the BT IP profile will be around 91% of sync speed so 72 Mbps looks about right to me.
22-08-2017 1:04 PM
22-08-2017 1:28 PM
I'd take a guess that may be the case for "retransmission low" i.e. a lower level of G,inp with lower overheads. The 91% profile comes about because the sync rate reported by the GEA test is lower than the actual router sync rate and the BT profile is based on this lower sync value.
22-08-2017 2:17 PM
So what exactly is G.INP? and is it something you want on the line or not? Sounds like its slowing down the sync rate a little bit.
22-08-2017 3:03 PM
22-08-2017 3:12 PM - edited 22-08-2017 3:16 PM
I'm in the pub so linking may not work
