G.INP and ECI
- G.INP and ECI
G.INP and ECI
17-03-2015 6:08 PM
yes here it comes.
simple question, has anyone on a ECI cabinet had G.INP enabled on their line?
On MDWS quite a few huawei have it enabled as seen here http://www.mydslwebstats.co.uk/HG612-MultUsersLivei.htm
Not a single ECI has it enabled, even ones with very recent DLM changes.
Plusnet can you clarify the stance on ECI with G.INP if possible.
Message 1 of 2
(1,010 Views)
1 REPLY 1
Re: G.INP and ECI
17-03-2015 6:36 PM
I'm on a ECI cab but I wouldn't be able to check stats to confirm as my BTO modem is locked and is ECI also, that said there hasn't been any changes to my SYnc, Profiles or anything else in nearly 4 months so I guess that could be a sign nothing has been enabled but as i say i cant check to be sure.
Message 2 of 2
(500 Views)
