G.INP & Throughput
- Re: G.INP & Throughput
G.INP & Throughput
23-03-2015 9:10 AM
All the usual test conducted via wired connection via BTW Speed Tester, and also Namesco to confirm.
Namesco: Download Speed: 49745 kbps (6218.1 KB/sec ) Upload Speed: 15573 kbps (1946.6 KB/sec )
Re: G.INP & Thoughtput
23-03-2015 9:37 AM
if nothing has changed one of the CRT should be able to do it for you, once done you will need to drop the session in the router again.
23-03-2015 9:41 AM
23-03-2015 9:55 AM
23-03-2015 11:39 AM
However, looking at the Max connected Speed shows Down has increased somewhat ( roughly 25%), Up considerably (roughly 90% oddly) but there has been no increase in the speed that I am receiving or transmitting at the router. It's as if speeds have been fixed, like they are on rails, and nothing will budge them.
23-03-2015 11:42 AM
23-03-2015 11:51 AM
At the PC I'm showing 30Mbps like its cast iron. Using internal wiring through adaptors and Cable connection. If I go direct to the router I get about 1.5Mbps increase.
23-03-2015 7:14 PM
23-03-2015 10:09 PM
23-03-2015 10:30 PM
Quote from: Starmans PN have reset line speed and after reset of PPP session I'm now getting the correct speed.
Was this Plusnet action automatic or because you raised it?
24-03-2015 8:07 AM
