Fttp Availablity
- Fttp Availablity
Fttp Availablity
25-05-2018 7:15 PM
Does anyone have any indication when Fttp will be available as a full product?
Openreach have now laid all the necessary cables along the front of the house and I would much rather go with Plusnet than BY, who are the only option just now!
Re: Fttp Availablity
25-05-2018 7:44 PM
You can check your house availability using the following
http://www.dslchecker.bt.com/adsl/adslchecker.welcome
You need to see "WBC FTTP" in the left hand column - there should also be a column with "1 stage" or "2 stage"
In the narrative below there will be a paragraph about FTTP which might say something like "UG Feed not evaluated"
If It's available and you're a PlusNet customer then you will be accepted onto the Trial (I've not heard of anyone being refused).
25-05-2018 7:58 PM
The complete list of the FTTP providers using the Openreach WBC FTTP can be found at https://www.homeandbusiness.openreach.co.uk/fibre-broadband/ultrafast-broadband/ultrafast-fibre-buy-...
So it isn't just BT or Plusnet. There are a few others too.
