Frequent short dropouts
Minglukhan
Hi Everyone,
Moved from standard broadband to fibre recently and although the speed is as expected I do experience frequent short dropouts. This manifests itself in WhatsApp messages hanging waiting to send waiting for a connection, internet radio cutting out regularly and also general web browsing pausing waiting for connection.
I will be working from home soon and need a stable connection, can someone please test my connection/line?
5 REPLIES 5
Thrall
Seasoned Pro
Fixes: 23
Re: Frequent short dropouts
Does the light on the front of the router change colour when the connection drops for you?
It’s a good starting point to see if the broadband’s dropping or the wireless signal is.
Minglukhan
The light remains blue - even during the dropouts.
Minglukhan
I see it's a common theme on the forum, is there a general consensus on the cause/solution?
Thrall
Seasoned Pro
Fixes: 23
Sounds like an issue with the wireless signal which can have a variety of causes, mostly down to environmental. Could try the steps here https://community.plus.net/t5/Plusnet-Blogs/How-to-boost-your-wi-fi/ba-p/1450193
MikeLewis
Hi, I had this problem for ages. See my post here, it may help you
https://community.plus.net/t5/Fibre-Broadband/Plusnet-Hub-one-intermittent-dropout/m-p/1745600/highl...
Cheers, Mike
