Frequent drops, sluggish speeds - Again!
Mustrum
Fixes: 60
Re: Frequent drops, sluggish speeds - Again!
@sw4mpl0rd  have you got a static ip by any chance?
sw4mpl0rd
... yes, I do!
Fixes: 1,139
@Mustrum wrote:
@sw4mpl0rd  thanks, as suspected seems your PN profile needs a tweak.
Yep it sure does, @sw4mpl0rd can you reboot your router? Let me know what your speed looks like afterwards.
What improved your sync speed though is a mystery if the engineer didn't find anything wrong, because your line went from 15mbps before the visit and we found a "Impairment in copper joint" to 52mbps afterwards with tests now seeing no fault.
sw4mpl0rd
Rebooted, stats all look the same so far.
sw4mpl0rd
Fixes: 84
@sw4mpl0rd - Can you run a speed test, and post that members centre screen grab?
Fixes: 1,139
Your stats won’t change because I haven’t made a change to your sync speed. Your throughput however should be a lot better now. Can you run a speed test?
sw4mpl0rd
Latest wholesale speed test attached : 15 down / 13 up
Fixes: 84
Well, the profile is correct, but the speed test is strange.
Fixes: 1,139
Hmm. Try running a speed test Here instead to cross-reference
sw4mpl0rd
Fixes: 1,139
That shows you're getting more than what the previous profile was at 15.9mbps so doesn't seem to be anything this side affecting your speed especially now that the profile is 52mbps. Do you have another device to test from?
Fixes: 84
@sw4mpl0rd Just a thought - have you dropped the PPP session - might pick the new profile up properly if you do?
sw4mpl0rd
Thanks for all the help, guys. Whatever the gremlin was... he's gone!
We're back up to 48 down / 13 up!
Fixes: 84
Thumbs_Up 👏
