Frequent drops, sluggish speeds - Again!
- Re: Frequent drops, sluggish speeds - Again!
03-09-2021 5:48 PM
@sw4mpl0rd have you got a static ip by any chance?
03-09-2021 5:49 PM
... yes, I do!
04-09-2021 7:13 AM
@Mustrum wrote:@sw4mpl0rd thanks, as suspected seems your PN profile needs a tweak.
Yep it sure does, @sw4mpl0rd can you reboot your router? Let me know what your speed looks like afterwards.
What improved your sync speed though is a mystery if the engineer didn't find anything wrong, because your line went from 15mbps before the visit and we found a "Impairment in copper joint" to 52mbps afterwards with tests now seeing no fault.
04-09-2021 8:12 AM
04-09-2021 9:21 AM
Attached the stats for you
04-09-2021 10:00 AM
@sw4mpl0rd - Can you run a speed test, and post that members centre screen grab?
04-09-2021 10:29 AM
04-09-2021 10:44 AM
Latest wholesale speed test attached : 15 down / 13 up
04-09-2021 10:47 AM
Well, the profile is correct, but the speed test is strange.
04-09-2021 1:24 PM
Hmm. Try running a speed test Here instead to cross-reference
04-09-2021 1:47 PM
04-09-2021 4:51 PM - edited 04-09-2021 4:51 PM
That shows you're getting more than what the previous profile was at 15.9mbps so doesn't seem to be anything this side affecting your speed especially now that the profile is 52mbps. Do you have another device to test from?
04-09-2021 5:04 PM
@sw4mpl0rd Just a thought - have you dropped the PPP session - might pick the new profile up properly if you do?
04-09-2021 5:08 PM
Thanks for all the help, guys. Whatever the gremlin was... he's gone!
We're back up to 48 down / 13 up!
04-09-2021 5:10 PM
