Frequent dropouts on Unlimited Fibre
- Frequent dropouts on Unlimited Fibre
19-03-2021 11:25 AM
With a fairly new router, my WiFi has become mainly usable. HOWEVER, even using a desktop computer with a LAN connection I am experiencing frequent unpredictable dropouts as well as the speed dropping from 70 to around 20 on occasion. The dropout is important as I am trying to log on to meetings from home during lockdown. Zoom and Skype can be almost impossible to use at times. And yes, I've done the internal checks!
Re: Frequent dropouts on Unlimited Fibre
21-03-2021 3:01 PM
Yes, same here, there seems to be no pattern, sometimes in the middle of the night when nobody in the house is using it.
21-03-2021 3:51 PM
PlusNet don't monitor connections for problems; they also don't turn up here very often now. You will need to ring in, or try reporting your faults at http://faults.plus.net/
