Frequent disconnects since starting service a month ago
- Re: Frequent disconnects since starting service a ...
21-01-2021 10:12 AM - edited 21-01-2021 10:15 AM
I get disconnected frequently, and the router shows either an Orange light or a flashing Orange light (this might be due to how long it takes me to look at it, I'm not sure).
Yesterday this happened at least 6 or 8 times, including three times between 9pm and 10pm.
I powered the router off anf on yesterday evening and it has been stable today so far (8am-10am) but the advice suggests I should be able to leave the rotuer on all the time.
I've performed the troubleshooting tasks, and have run an online Line Check using the plus.net link.
I have turned off the linking of 2.4 and 5ghz
I was with BT before Plusnet and didn't have these problems.
Could there be an issue with my router?
Re: Frequent disconnects since starting service a month ago
21-01-2021 12:09 PM
I have been having this problem quite frequently in the last month. Yesterday was quite bad as the connection dropped off every 30 mins or so!
21-01-2021 12:42 PM - edited 21-01-2021 12:43 PM
Could be, might even be a line fault. Is this connected WiFi or ethernet cable?
Do you still have your old BT router? If so have you tried using that to see if it IS the PN router playing up? You'll need to change the log in details on the BT router to the PN ones.
21-01-2021 5:48 PM
I've run the line check, and it reported no issues. There were also no issues (like this) with my previous provider using the same line.
I've sent the BT router back to avoid incurring charges from them, so I can't compare
21-01-2021 5:48 PM
So it's possibly not just me then! It has been better today, no dropped connections at all so far...
