Frequent disconnection
- Frequent disconnection
19-06-2020 1:28 PM
Hi
I’m experiencing frequent disconnection almost every 20 mins. The disconnection last for about 5 seconds after which it reconnects automatically. If I’m using my mobile, this would be unnoticed. However, on my computer every time this happens I get logged out from remote servers I’m connected to so this is becoming annoying. Can you suggest something ?
Thanks a lot for your help.
Message 1 of 5
(723 Views)
4 REPLIES 4
Re: Frequent disconnection
19-06-2020 3:15 PM
This happens often with me too, it does get annoying.
Message 2 of 5
(703 Views)
20-06-2020 7:15 PM
I’ve also been getting daily disconnects, sometimes more than once a day, and my wifi speed is way below my Minimum Guaranteed promise
Message 3 of 5
(658 Views)
21-06-2020 12:55 PM
I'm getting daily disconnections which require a router reset.
Link to thread I posted
https://community.plus.net/t5/Fibre-Broadband/Plusnet-Hub-one-intermittent-dropout/td-p/1745052
Are you experiencing the same thing?
Cheers, Mike
Message 4 of 5
(631 Views)
21-06-2020 1:24 PM
Hello Mike
Not quite the same thing for me. I’m getting the dropouts and the router lights changing but then my router automatically boots to ‘normal’. I don’t have to physically reset anything myself.
My other annoyance apart from the dropouts is that my wifi speed is much less than it should be and can fluctuate between 9 and 29 Mbps (download). On occasions my upload speed has barely crept above 1!
Message 5 of 5
(620 Views)
