Frequent Disconnects
Started getting disconnects every hour or so...
Checked the Router Profile and i get this on the check...
Not sure if it has anything to do with it. Contacted Tech support and they have sorted out a new router...
Any Ideas?
1 REPLY 1
Fixes: 392
Re: Frequent Disconnects
Sorry to hear you've been having issues.
Our tests aren't showing any faults on the line so it may be a router issue.
Let us know if the new router doesn't fix it.
 Matthew Wheeler
