Flaky Connection
- Flaky Connection
Flaky Connection
04-02-2015 5:12 PM
My connection seems to be very flaky the past couple of days. Getting lots of 'page cannot be displayed', no response to URL requests and general sluggishness. I just wondered what might be wrong? My speeds look ok I think? I did get a new PPP session yesterday to see if that helped but it didn't seem to make any difference. Using the ECI Openreach modem along with the PlusNet Technicolor fibre router. Connected with LAN cable.
Message 1 of 4
(665 Views)
3 REPLIES 3
Re: Flaky Connection
04-02-2015 5:36 PM
Try a different DNS provider, sounds like a case of flaky DNS servers to me
Message 2 of 4
(400 Views)
04-02-2015 5:52 PM
Hi woodm,
I've experienced simlar problems with Plusnet superfast fibre since having it installed in December. It's a good job I'm already bald!!
After reading another thread on this forum here, I did as deathtrap suggests above.
To expand on his advice, can I suggest you have a look here and alter your DNS servers to Google's Public DNS servers as a test.
I changed my DNS servers for both IV4 and IV6 and it solved my issue instantly.
Message 3 of 4
(400 Views)
04-02-2015 7:04 PM
Thanks both. I switched over to Google's DNS and saw a marked improvement. Maybe OpenDNS is having some problems at the moment. At least it seemed that way for me the past couple of days.
Message 4 of 4
(400 Views)
