Fixed WAN IP Address?
nigelmercier
Before I upgraded to fibre I had a fixed IP address. Can someone please check that this is still the case please?
I ask because last time I changed my package I got put back in the pool.
Fixes: 173
Re: Fixed WAN IP Address?
You have a static IP address on your account. As far as I can see this hasn't changed over the past 12 months.
 Harry Beesley
nigelmercier
Odd, I was told it would change. Thanks.
Fixes: 6
The Hub One is unlikely to be much help for what you need, AFAIK it doesn't do multiple IP's and can not be configured as bridge (modem only) mode.
Can your old router work with a HG612 VDSL modem from ebay?
Failing that you're looking at a expensive new VDSL modem/router.
This link shows popular fibre modem/routers, not sure which are suitable for multiple IP's.
http://forum.kitz.co.uk/index.php/topic,14436.0.html
Fixes: 46
