Fixed DL speed
- Fixed DL speed
Fixed DL speed
08-01-2017 10:00 AM - edited 08-01-2017 10:00 AM
@Anoush ,
hi ,
i performed a hard reset and now get the standard 34+ Mbps DL speed.
Thanks for previous advice in this matter
~ crypto_sloth
Re: Fixed DL speed
08-01-2017 10:13 AM - edited 09-01-2017 8:57 AM
Yay. Apologies for not replying to your private message today.I'll run a few tests down your line tomorrow just to make sure things are as they should be on our side.
Looking at your connection, things seemed a bit unstable late last night.
I've tested your broadband, and a possible local network fault has been detected.
Main Fault Location | LN |
Sync Status | In Sync |
Downstream Speed | 38.2 Mbps |
Upstream Speed | 2.0 Mbps |
I'd recommend getting this reported to us at http://faults.plus.net and I'll push this through to suppliers.
