Fixed DL speed
crypto_sloth
Fixed DL speed
@Anoush ,
hi ,
i performed a hard reset and now get the standard 34+ Mbps DL speed.
Thanks for previous advice in this matter
~ crypto_sloth
1 REPLY
Plusnet Staff
Plusnet Staff
Fixes: 117
Re: Fixed DL speed
Yay. Apologies for not replying to your private message today.
I'll run a few tests down your line tomorrow just to make sure things are as they should be on our side.
Looking at your connection, things seemed a bit unstable late last night.
 I've tested your broadband, and a possible local network fault has been detected.
Main Fault Location LN
Sync Status In Sync
Downstream Speed 38.2 Mbps
Upstream Speed 2.0 Mbps
I'd recommend getting this reported to us at http://faults.plus.net and I'll push this through to suppliers.
From when I joined the Plusnet Help Team in May 2017 my main Community account is @Gandalf.
 Plusnet Staff
