Firmware update without factor reset?
- Re: Firmware update without factor reset?
12-10-2017 1:40 PM
Hi. My BB is being a little tempremental at the moment. Nothing too bad, but a friend has suggested a firmware update might help. I've just been told by plusnet support that I would need to do a factory reset in order to force a firmware update. I'd rather not do this as I'll lose the config on the router. Has anyone managed a firmware update without having to do a factory reset? I have a Technicolor TG582n.
Thanks.
Message 1 of 2
(545 Views)
1 REPLY 1
12-10-2017 2:52 PM
Message 2 of 2
(521 Views)
