Firbre: New Modem/Router Stats
andun84
So got myself a new modem/router. The Asus DSL-AC68U and finally I get to see stats. Is there anything interesting in them? Doubt it Cheesy
DSL Uptime
0 days 1 hours 47 minute(s) 53 seconds
DSL modulation
ITU G.993.2(VDSL2), G.998.4(G.INP)
ANNEX Mode
ANNEX B
SNR Down
6.0 dB
SNR Up
7.6 dB
Line Attenuation Down
10.9 dB
Line Attenuation Up
0.7 dB
Path Mode(downstream)
FastPath
Path Mode(upstream)
FastPath
Data Rate Down
59802 kbps
Data Rate Up
18998 kbps
MAX Rate Down
77192
MAX Rate Up
21583
POWER Down
14.1 dbm
POWER Up
6.9 dbm
CRC Down
0
CRC Up
8
Estragon
Re: Firbre: New Modem/Router Stats
A rather poor downstream connection speed I would have thought.
Status: Showtime
Retrain Reason: 2000
Last initialization procedure status:  0
Max:    Upstream rate = 14197 Kbps, Downstream rate = 56512 Kbps
Bearer: 0, Upstream rate = 14040 Kbps, Downstream rate = 57676 Kbps
Bearer: 1, Upstream rate = 0 Kbps, Downstream rate = 0 Kbps
Link Power State:      L0
Mode:                  VDSL2 Annex B
VDSL2 Profile:          Profile 17a
TPS-TC:                PTM Mode(0x0)
Trellis:                U:ON /D:ON
Line Status:            No Defect
Training Status:        Showtime
                Down            Up
SNR (dB):        6.2            6.3
Attn(dB):        19.8            0.0
Pwr(dBm):        13.5            7.4
Compare your downstream rate with your Max downstream. I know my equivalent ones look to be the wrong way round, but that is common with the HG612 modem. Also compare your downstream attenuation with mine.
rongtw
Fixes: 12
i  have the same router my stats say
DSL Firmware Version 1.0.2.9
DSL Driver Version FwVer:5.5.1.131_B_A60901 HwVer:T14.F7_0.2
DSL Link Status
up
DSL Uptime
3 days 23 hours 9 minute(s) 31 seconds
DSL modulation
ITU G.993.2(VDSL2)
ANNEX Mode
ANNEX B
SNR Down
5.2 dB
SNR Up
10.5 dB
3.2 dB
Line Attenuation Up
0.1 dB
Interleaved
Path Mode(upstream)
FastPath
Data Rate Down
79999 kbps
Data Rate Up
20000 kbps
MAX Rate Down
106132
MAX Rate Up
27349
POWER Down
10.2 dbm
POWER Up
-9.6 dbm
CRC Down
33009
CRC Up
720
