Finding my IP remotely
- Finding my IP remotely
25-05-2018 9:14 AM
Hi, as the message says - is there anyway to find my IP remotely as it isn't listed in the control panel under settings? I need to RDP to my machine at home but since the last time I did this it seems my IP address has changed.
Re: Finding my IP remotely
25-05-2018 10:12 AM
Type IP into Google search
25-05-2018 10:24 AM
Thanks for responding but I am not at the computer or in the same location as the connection hence the need to RDP in to it, I was hoping to get my routers current IP from the control panel on plus.net but it doesn't list it.
25-05-2018 10:32 AM
Nobody at the other end ?
25-05-2018 10:33 AM
If you're using RDP I would suggest asking PlusNet for a fixed IP.
There is a fixed charge of £5 I believe.
25-05-2018 10:34 AM
Thanks guys - no one at home sadly. Wasn't aware I could get a fixed IP, i'll look into it thanks for the heads up.
25-05-2018 11:54 AM
