Fibre wont connect
- Fibre wont connect
Fibre wont connect
23-11-2018 1:53 PM - edited 23-11-2018 2:10 PM
When I log into the sign in page it says i'm not connected. I try entering my username and password, it does the PPP symbol spinning thing, then goes back to the same page saying i'm still not connected. I spoke to plusnet who confirmed everything is working properly, however it clearly isnt. I tried resetting the router, factory reset, everything, Plusnet have even sent me a new router but that has the same issues. This leads me to think that its an issue at their end (i've used my house phone which is plugged into the same port with no issues).
Does anyone know how this can be resolved as I have been without internet for 2 weeks now and only been with Plusnet for 4 weeks!
Thank you
Re: Fibre wont connect
23-11-2018 3:13 PM
Have you tried a different microfilter?
23-11-2018 3:22 PM
Hi Baldrick
Thanks for the response. Yes i've tried a new filter and tried taking off the face plate and connecting directly into the "hidden" port. Also i've tried it without a microfilter at all.
Could it be anything to do with Plusnet somehow (incorrectly) blocking my account or some admin issue?
23-11-2018 3:28 PM
Have logged into the router and looked at the logs to see if you get any clues from them?
Have you by chanced changed yout member centre password recently? This should be the rame as the router.
23-11-2018 7:21 PM
Hi @sammers14,
Thanks for the update.
At this point we're going to need to get an engineer out to ascertain what's going on.
I've just sent out a ticket accessible here which we do need a response to in order to book the appointment.
Please let us know when you respond, so that we can take any necessary action for you ASAP.
