Fibre with router
gbonthron
Fibre with router
I'm currently running a TP-Link TD-8817 modem connected to an Asus RT N16 wireless router. I'm getting Fibre installed tomorrow, am I right in understanding that once that's set up with the BT Modem, I can basically just hook up my RT N16 for the wireless? Is there anything special I need to do this?
2 REPLIES 2
pwatson
Re: Fibre with router
Assuming the RT-N16 is acting as the router for your network, it should be straightforward - You'll need to configure the Asus WAN port for PPPoE and put in your PN username and password.
gbonthron
Good good. Cheers!
