Fibre upgrade
Richywiseman
Fibre upgrade
Hello, after waiting over a year for my green cabinet to get power, I have finally managed to order fibre ! 3mb Down and .25mb up for 10 years...........and I live 200m from the fibre cabinet :-)
I really like my Netgear router I currently use on ADSL, unfortunately it is not VDSL compatible. I have ordered the Plusnet router One, but I would like to continue using my existing router as is setup the way I like, and has good range. Can I use the Plusnet One as purely a modem (Turning off the WIFI) and connect this to my existing router via Ethernet to handle the WIFI?
Many Thanks
Richy
Fixes: 79
Re: Fibre upgrade
Hi, you might find this post helpful for that: https://community.plus.net/t5/Fibre-Broadband/Can-the-Plusnet-Hub-One-be-put-into-Bridge-mode/td-p/1...
 Adam Walker
Richywiseman
Re: Fibre upgrade
Thank You.
Richy
