Fibre upgrade
Collette69
Fibre upgrade
I've upgraded to fibre broadband and it was meant to go live today 2/09/16 anyway I was told to wait for a text/email before I set up my new router and now my normal broadband is messing up can't get no connection I've done all the tests on the line any advice?
VileReynard
All Star
Fixes: 11
Re: Fibre upgrade
Maybe you have been actually switched over & you could try plugging the new router in?
Just a guess...
Collette69
Re: Fibre upgrade
That worked was just abit wary about installing the new router thanks
VileReynard
All Star
Fixes: 11
Re: Fibre upgrade
Wow!
You will learn that Plusnet communications are "sluggish".
