Fibre upgrade
FIXED- Subscribe to RSS Feed
- Re: Fibre upgrade
- « Previous
- 1
- 2
- Next »
29-08-2016 6:09 PM
Looking at the settings you gave me I have only one which is different and that is use VLANID = 101 Priority = 0.
All the rest are exactly the same. Is there some significance to the LLANID?
Re: Fibre upgrade
29-08-2016 7:23 PM
There is, have you tried changing it to that? And do you have the latest firmware on the router ?
Re: Fibre upgrade
29-08-2016 7:26 PM
I will try that tomorrow.
many thanks for your help today.
Re: Fibre upgrade
29-08-2016 7:27 PM
Just to add the latest firm ware on the router appears to have problems with wifi so I havent upgraded.
Re: Fibre upgrade
30-08-2016 3:47 PM
Hi - just to say I put in the code you gave me VLAND and amazingly it has worked!! Cant believe it! I would never have achieved this without your help. I have no clue what Vland is but it worked.
My download speed has increased to 52mbs but upload has gone down slightly to 4.35. Not over worried as I rarely upload. My next door neighbour is getting much better speeds than me - also with plusnet!
Many thanks for your help.
- « Previous
- 1
- 2
- Next »
