Fibre upgrade
- Fibre upgrade
Fibre upgrade
04-05-2015 5:59 PM
Re: Fibre upgrade
04-05-2015 6:03 PM
Re: Fibre upgrade
04-05-2015 6:47 PM
Re: Fibre upgrade
04-05-2015 7:56 PM
Re: Fibre upgrade
04-05-2015 9:25 PM
Re: Fibre upgrade
05-05-2015 6:29 PM
Re: Fibre upgrade
05-05-2015 7:58 PM
Re: Fibre upgrade
12-05-2015 2:35 AM
Quote from: plusnettony You'll be getting a new router which should be with you in a few days......... This would normally be done automatically, but your order was placed manually so additional work might be required.
Without wishing to hi-jack this thread, can I ask whether the replacement Router will be an integrated VDSL Modem/ Router (or are PlusNet still using the BT OpenReach supplied Modem and separate Router)?
Can you also tell me the make and Model of the Router that PlusNet now supply.
A Green Cabinet has appeared on the corner of my street and the BT Checker says that the Exchange is enabled and will be taking orders soon!
Re: Fibre upgrade
12-05-2015 9:56 AM
Quote from: Wheel_nut can I ask whether the replacement Router will be an integrated VDSL Modem/ Router (or are PlusNet still using the BT OpenReach supplied Modem and separate Router)?
No, BT modem and separate router still.
Quote from: Wheel_nut Can you also tell me the make and Model of the Router that PlusNet now supply.
Sagem 2704N (referred to as 'Plusnet 2704n' here)
Re: Fibre upgrade
12-05-2015 6:24 PM
Thank you for the reply W23. I was hoping that PlusNet would have adopted the sensible solution of an integrated VDSL Router like the BT Home Hub 5 or the DLINK unit that SKY are now providing. Both of those units as compact and neat and only require One Power Point and no spaghetti, allowing it to be placed at the incoming Master Socket position which is usually in the Hall.
I won't be taking the PlusNet offering unless this changes. My current contract runs ouut in July so I will check again before I jump ship.
Re: Fibre upgrade
12-05-2015 7:06 PM
